Thread: Voltage reads 13.1-13.5 while running
Results 1 to 20 of 26
  1. #1 Voltage reads 13.1-13.5 while running
    SE Level Member blackthunder's Avatar
    Jun 2013
    London, Ontario
    So i bought the voltage booster from ZZP (along with a few other things ) and I used the Torque program to see a "before" voltage before installing. I noticed that while running it only read 13.1-13.5 volts. Now i know my battery is going because if the car sits for more than 2 days the battery is dead.
    Now is it only reading that because I have a dead cell in my battery? or is it an up and coming alternator issue?
  2. #2 Re: Voltage reads 13.1-13.5 while running
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Your voltage should be 11.5-12 volts when resting and no more than 13.5 when running. The alternator shouldn't put out more than 14 volts, remember this is a 12 volt system. I have a 1999 Freightliner I use around the farm. It has 3 batteries and the alternator only puts out 14.5 volts.
  3. #3 Re: Voltage reads 13.1-13.5 while running
    check the volts at the battery while running, dead battery could take some more power to charge it back up.
    you can also have the battery load tested, this will tell just how bad it is. parts stores do this for free. volts and load test.
  4. #4 Re: Voltage reads 13.1-13.5 while running
    SE Level Member trey9778's Avatar
    May 2013
    Orlando, Fl
    I bought my voltage booster from zzp also and I received and installed it yesterday. My voltage is reading out 15.2 - 16.0! I think I might be removing mine..
    2002 Grand Prix GTP White 4-Door 81K - Homemade Hai, 93 octane, Royal Purple, k&n Gold, Flipped Mounts, Aux Input, kicker Solo Barics and kicker tweeters, 5K HIDs, Scanguage II, ZZP PCM, Performance Shift.
  5. #5 Re: Voltage reads 13.1-13.5 while running
    Jun 2013
    London, Ontario
    Did you get the stage 2? I only got the stage 1. With the voltage booster installed im getting 14.4-14.5 volts.
    Ill do more testing at home with the volt meter
  6. #6 Re: Voltage reads 13.1-13.5 while running
    Quote Originally Posted by lewis1952 View Post
    Pretty wrong, the alternator should put at least 13.5 to 14.5 volts always.
    You'll see upwards of 15 volts on really cold starts and while idling to get the engine warm, then drops to normal.
    Every single car that I do charging system checks on reads atleast 14 volts at some point in time.
  7. #7 Re: Voltage reads 13.1-13.5 while running
    GTX Level Member blackflag's Avatar
    Virginia
    Not trying to be a dick but who buys a voltage booster? It has no value in a gtp. Maybe IM wrong...
  8. #8 Re: Voltage reads 13.1-13.5 while running
    Helps gives you a bit more voltage.. Guys that have dimming headlights etc it can help. But doing the big 3 is a better idea
    04 Comp G.
  9. #9 Re: Voltage reads 13.1-13.5 while running
    SWPA
    More voltage is a bad idea though. Having cleaner grounds will net better results than higher voltage.
  10. #10 Re: Voltage reads 13.1-13.5 while running
    May 2013
    Orlando, Fl
    @ blackthunder yeah I bought stage 2. Im gonna take it out tonight. And the purpose wasnt to increase my cars value. It was to increase voltage to make windows roll up and down faster etc.. and to keep my amps near 14.4 volts.
  11. #11 Re: Voltage reads 13.1-13.5 while running
    Yea I would pull that stage 2 before you mess something up.. Want to make your windows roll up faster.. Upgrade the grounds to better gauge wiring.
    04 Comp G.
  12. #12 Re: Voltage reads 13.1-13.5 while running
    May 2013
    Orlando, Fl
    I noticed when the car was at higher volts (15+) the dic flashed whenever I put a load on the car. Its out now.
  13. #13 Re: Voltage reads 13.1-13.5 while running
    Nov 2011
    NY
    It's a gimmick and does absolutely nothing to INCREASE power or voltage. All it does is relieve you of some cash from your pocket. Sure, your meter may read an increase in voltage, but its all smoke and mirrors. You can make your own with a $2 power diode from Radio Shack and some heats shrink tubing. Sorry to bust your bubble, but there's no magic bullet. You need a bigger alternator or less resistance in your wiring to make any real effect as noted.
    edit: and YES the 15 volts is definitely going to screw some things up. If you read their (ZZP) disclaimer, it tells you that the stage II unit may cause over voltage problems. Lol...
  14. #14 Re: Voltage reads 13.1-13.5 while running
    Jul 2010
    Coquitlam,BC,Canada
    I had a stage 1 booster for 3 months. It took out my battery by hitting 15.2 volts. It went in the parts pile and I now am at 13.9-14.1 volts.
    I wish I had my Aeroforce back then so I could have prevented the overcharging.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: Voltage reads 13.1-13.5 while running
    Pennsylvania, USA
    I've had a DC Power HO alternator in my car for about 3 years now, and it charges at around 15-15.5v at all times. I haven't had any issues, but at the same time I run all dry cell/AGM batteries in my car (one in front and one in the trunk), so they may like higher voltages than standard batteries can take.
    So IMO it's up for grabs whether or not charging above 15v is safe for your batteries.
  16. #16 Re: Voltage reads 13.1-13.5 while running
    May 2013
    Orlando, Fl
    yeah its back to 13.8 -14.4 now.
  17. #17 Re: Voltage reads 13.1-13.5 while running
    GTP Level Member
    springfield IL
    Would a bad alternator lead to engine whine...?? I've checked ALL my wiring this week!! Battery voltage seem fine tho.
  18. #18 Re: Voltage reads 13.1-13.5 while running
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    The stage 2 is for "Race Applications Only" or something according to ZZP.
    2012 F150 STX
    - Gonna be a race truck
  19. #19 Re: Voltage reads 13.1-13.5 while running
    Dec 2012
    troll land
    Yeah it could b alt going bad. An alternative is run a park av alt. 140 amp 97-99. 125 amp 99+
  20. #20 Re: Voltage reads 13.1-13.5 while running
    SWPA
    Quote Originally Posted by tc300 View Post
    Have you checked power steering fluid?
  1. Boost reads in the negative?
    By h0wl0ngcanitbe in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2013, 12:17 AM
  2. Gauge reads around 210
    By beattie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2013, 01:57 PM
  3. o2 reads 0 mv at times
    By James Case in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2012, 11:41 AM
  4. Boost gauge reads zero
    By COEBAM in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2010, 09:44 AM
  5. No one reads the Please Read
    By IndeedSS in forum Off Topic Discussion
    Last Post: 12-28-2007, 02:56 PM
