Thread: Oil Pump
Results 1 to 2 of 2
  1. #1 Oil Pump
    Nov 2013
    bristol, tn
    Does anyone know where or how the dot on the oil pump drive lines up? Thanks
  2. #2 Re: Oil Pump
    hangover park IL
    the oil pump drive spline on the front of the crank gear doesnt need to be timed to the cover/pump's inner scroll
    the dot near the teeth is for timing it with the cam gear.
    unless your refering to an aftermarket timing set but you sure didnt give much for specifics or pics of the issue...
    ~James~ Psychotic Gearhead
  1. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  2. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  3. GTP Fuel pump.. Will a GT pump work?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2012, 01:19 AM
  4. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  5. 42.5# Injectors, Flowjet pump, ZZP pump controller
    By StamperGTP in forum For Sale - Parts
    Last Post: 01-10-2012, 02:33 PM
