Thread: Throwing codes
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 99
  1. #1 Throwing codes
    Banned
    Dec 2013
    Indiana
    Po243
    Po300
    Po452
    P1133
    P1653
    What do they mean?
  2. #2 Re: Throwing codes
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    a quick google search can help you with that.
    P0243 Supercharger wastegate solenoid fault.
    P0300 Random multiple cylinder misfire
    P0452 Evaporative emission control system pressure sensor low
    P1133 Bank 1 sensor insufficient switching
    P1653 5V Reference (B or 2) Circuit
    did you move anything recently on the engine bay? Symptons?
    If You Cant Hear The Whine You're Too Far Behind...
  3. #3 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Thanks. Yeah. I disconnected some stuff and replaced the plugs
  4. #4 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    I plugged everything back in..... I think......
  5. #5 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Dang it
  6. #6 Re: Throwing codes
    SE Level Member rockquarryman's Avatar
    Nov 2013
    so co
    sounds like someone needs just an old fashion tune up
    Quote Originally Posted by GTP89 View Post
  7. #7 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Changing the plug wires now.
  8. #8 Re: Throwing codes
    this is your plug and wire locations, in case you mix a wire up.
  9. #9 Re: Throwing codes
    Buena Park Ca
    might be a little more serious then that. i have been chasing down certain codes you have listed for a while and haven't been able to figure it out. Lmk how it goes as it might help me out as well lol
  10. #10 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Well the wires didn't help dang it
  11. #11 Re: Throwing codes
    the random misfire code could be cause the gaps to tight, open them back up to 45 and see if that helps. with that code at least.
  12. #12 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    I must have screwed something up last night. New plugs and the only other thing I did was change the gap.
    There are some plugs flopping around under the hood. I'm wondering if any of those are supposed to be plugged in?
  13. #13 Re: Throwing codes
    Buena Park Ca
    Possibly, but there must be something causing all this issue, to me just how i think mine is, is more of a electrical issue, his 5V reference is pulling a code, meaning there might be a short somewhere. That 5v reference controls practically all electricals in the car mainly engine. so if that is bad it can throw off the icm which throws off spark and so on. Hopefully it is something easy for him. but depending on what all he did and disconnected or moved will help.
  14. #14 Re: Throwing codes
    Buena Park Ca
    Quote Originally Posted by traildog View Post
    What plugs? you should have all of them connected. post a pic of them.
  15. #15 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    I'll take pics and post tomorrow. I'm pooped and my "pansy hands" hurt. BWAAAAAAAAAAA!
    Thanks for all the help. We'll get it figured out eventually.
  16. #16 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    OK. So here come the pics of the stuff not plugged in. First, I pulled one of the new plugs to have a look.
    Found this just flopping around.....What is it and where should it be?
    Why isn't this thing plugged in and what is it?
  17. #17 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Found this plug,
    And this plug,
    My feeling is, that this stuff wasn't needed after all the turbo stuff was added, but I'll need you experts to tell me...........
  18. #18 Re: Throwing codes
    [QUOTE=traildog;1182392]OK. So here come the pics of the stuff not plugged in. First, I pulled one of the new plugs to have a look.
    [/QUOTE
    first [pic is a the ait sensor, it would be in the intake tube.
    second pic is the egr, not sure why its there, no way its hooked up i bet.
  19. #19 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    So, I should put the ait sensor in the intake tube? Where exactly is that?
    The egr isn't necessary?
  20. #20 Re: Throwing codes
    not sure where it goes on a turbo car or if its used really, i just know what it is lol
    the round sensor, the egr, its sits on a pedestal and has flex tubes from the lower intake, to the rear exhaust manifold. dont think a plog had the hole for the egr, so it may be there just for looks. if it was unplugged it must be deleted.
  1. Replies: 5
    Last Post: 02-02-2013, 07:03 PM
  2. Just throwing this out there
    By DirtDog in forum Off Topic Discussion
    Last Post: 12-21-2012, 06:43 PM
  3. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  4. Changed o2 sensor and Still throwing out same codes!?????
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2011, 04:16 PM
  5. Throwing codes
    By batman1988 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2011, 03:37 PM
