Thread: 2005 Grand Prix Issues
Results 1 to 9 of 9
  1. #1 2005 Grand Prix Issues
    SE Level Member nicholearthur's Avatar
    Feb 2014
    Minnesota
    Ok, so I have been having a few issues with my 2005 Grand Prix GT 3800 V6.
    1. Transmission will intermittently shift hard. It usually starts when I get off the interstate and stop at a stop light and then go again. Talked to a transmission guy and have him see if there are any codes. He didn't even have to run the scanner and he was fairly certain what the problem was. He ran the scanner and sure enough it had a transmission solenoid code. So I think I have that problem narrowed down but would appreciate any advice if it could be anything else.
    2. I have a catalytic emissions code. I have the codes cleared and it seems to only pop the code when the transmission starts acting up.
    3. Sometimes I have a problem getting it started after sitting for a bit. Example, I will come home on my lunch break and let it sit for about 45 minutes and I go try and start it and it won't. Sometimes it takes 3 or 4 times before it starts and if that doesn't work, I have to give it some gas and it starts right up.
    4. My traction control off light comes on intermittently, and when the light is on it shifts hard, I will be driving 60 mph and it is still reading 2500 rpms. No ABS light on though.
    5. I have it set so my doors lock when put in drive and unlock when put in park. I noticed this around the same time that the traction control off light came on. And just tonight they didn't lock when I put in drive but after a few minutes of driving the randomly locked. I parked the car and after a few minutes I put it back in drive and they locked.
    Any help would be greatly appreciated. I don't want to start throwing parts at it.
    Thank you!!
  2. #2 Re: 2005 Grand Prix Issues
    Clean your throttle body
  3. #3 Re: 2005 Grand Prix Issues
    Feb 2014
    Minnesota
    I work at a mechanic/body shop and according to the mechanic he has cleaned the throttle body.
  4. #4 Re: 2005 Grand Prix Issues
    Feb 2014
    Minnesota
    The codes I have are
    P1811
    P0420
  5. #5 Re: 2005 Grand Prix Issues
    Clean it yourself so you know it's done right. Your cat is probably clogged
  6. #6 Re: 2005 Grand Prix Issues
    Doubt that cat is clogged, but just can't keep with with the standards that the motor wants.
    P1811 is the trans code, max adapt shift yadda yadda. I'd just get it rebuilt at that point or install a shift kit.
  7. #7 Re: 2005 Grand Prix Issues
    SE Level Member FASGP's Avatar
    Toronto ON
    I suggest you clean that TB as well as the MAF. Pretty much every 04+ I worked on when they have a start/stall issue is that, and it takes you 10 mins work using a residue free sensor cleaner on the MAF and rag on the TB.
    Sadly, your trans probably does have a bad solenoid. It is a bit of a chore to change it due to location, but it can be done. Trouble is, when the trans shop goes in, your 4th and 3rd clutches are probably going to need done anyways. I have seen these intermittent troubles run a long time and not fail, but you just never know. I would suggest a pan drop, filter change and Dex6 into it. While down, you can put in a trans go shift kit, which will help improve all shifting, and you may find the problem happens less.
    As for TCS light, and then the door locking, I wonder if there is not a loose ground somewhere. Suggest checking all ground points you can see to make sure its free of corrosion and tight.
    Vtec...All the lag and none the turbo...it's like waiting for bad sex
  8. #8 Re: 2005 Grand Prix Issues
    Feb 2014
    Minnesota
    Getting the solenoid replaced on Monday. According to the tranny guy this should take care of my problem without having to have it rebuilt. Here's to hoping that is the case!
  9. #9 Re: 2005 Grand Prix Issues
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    +1 to cleaning the TB yourself. You can pull it off easy and do a good job of it. I had that exact issue, and since then I just clean the TB once or twice a year.
    Like it was said, consider a pan drop and a fluid change. A shift kit will also help save your 4th gear hub.
    I have had the traction control and door look issue before, right after I bought my car. It was a bad wheel speed sensor and harness. I was still under factory warranty, so they put in 2 new wheel barrings (the sensor can't be separated, and they said another was almost shot), and a new harness for one of them.
  1. 2005 Grand Prix GTP Issues
    By whitefeathersnpr in forum General Tech Discussion
    Last Post: 03-21-2013, 12:09 PM
  2. Key Fob Issues - 2005 Grand Prix GT
    By Chris Taylor in forum General Grand Prix Discussion
    Last Post: 11-16-2012, 08:51 PM
  3. 2005 Grand Prix - temp gauge/cooling fan issues.
    By lateralus20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2011, 12:46 AM
  4. My New 2005 Grand Prix
    By extreme in forum 04+ Specifics
    Last Post: 08-10-2009, 10:18 AM
