Thread: P0301 Misfire Cylinder 1 Help
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    I have a 1999 Grand Prix GT with 170,000 miles. I drove to a basketball game 2 blocks away and it was perfectly fine and normal. After the game I started it up and it was vibrating really bad and the check engine soon was flashing so I knew it was misfiring. So today I started it up to drive into the garage and it was normal again. I checked cylinder 1 and noticed the plug and wire have been replaced before. The rest of the plus are delco but this one is an autolight double platinum 606. Would different plus cause a sudden misfire? Looking forward to your help. Thanks. Here are some pics. Do you think the delco plugs are original from factory?
  2. #2 Re: P0301 Misfire Cylinder 1 Help
    Blame the platinum plug, these motors hate plats.
    Replace with a delco iridium plug and it should be all good.
  3. #3 Re: P0301 Misfire Cylinder 1 Help
    tune up time. plugs and wires for all.
  4. #4 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    I agree with new plugs and wires but I was going to try to get by until around spring when it isn't freezing outside. Should it be OK to leave the autolight in until spring? Do you think the delco plugs are still original?
  5. #5 Re: P0301 Misfire Cylinder 1 Help
    change the bad plug for now then, should be ok.
  6. #6 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    OK, Thanks for the fast help. How do you know if the delco plugs are iridium? It doesn't say iridium on them.
  7. #7 Re: P0301 Misfire Cylinder 1 Help
    hard to say but being that one was changed or maybe they only had 5 plugs, so they tossed a plat in there, used cars, who knows right.
    first thing i do to a used car ive just bought is a tune asap. i start my own records.
  8. #8 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    I like that idea but I'm a 16 year old with not much money. That's why I love this forum. It saves me money!!
  9. #9 Re: P0301 Misfire Cylinder 1 Help
    one plug is like 6 bucks iirc
  10. #10 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    I know, sorry for the misunderstanding. I meant I like the idea of a tune up everything when you get the car but I don't have money for that. Haha. Thanks
  11. #11 Re: P0301 Misfire Cylinder 1 Help
    oh i get it, im cheap too lol
    but a tune up and oil change gets done right out of the gate. why would i trust what the last owner says?
  12. #12 Re: P0301 Misfire Cylinder 1 Help
    Pennsylvania
    41-101 is the ac part number for the plugs you should have in there if they're iridium.
    from the tip of the one ac plug you showed though, they look like platinum. You can see the little spot on the center electrode.
    Sport Edition Kv5 18x8
  13. #13 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    OK thanks, I think I'm going to order a set of delcos from rockauto.
  14. #14 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    My dad has his Buick that he doesn't drive anymore so I took a plug from it and put it in my car and it still vibrates bad. The weird thing is that when I start it up it is fine and smooth idle. After I drive it around the block it starts hesitating and vibrating bad.
  15. #15 Re: P0301 Misfire Cylinder 1 Help
    take the plug wire from your dad Buick too. if that dont fix it, try using one of his coils.
  16. #16 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    OK I will try that soon. There is also the possibility that the Buick's parts aren't very good anymore. It has 260,000 miles on it. Just to make sure, cylinder 1 is the front left...right?
  17. #17 Re: P0301 Misfire Cylinder 1 Help
    correct. cylinder 1 left front
    if your dads car runs im sure his parts are worth a try, even if its not running, its still worth a shot.
  18. #18 Re: P0301 Misfire Cylinder 1 Help
    Jan 2014
    AR
    I got this code just the other day and it was simply some bad gas. If you got gas at a different place than usual shortly before this happened, that could cause it.
    41-101, AC Iridium plugs are what I use.
  19. #19 Re: P0301 Misfire Cylinder 1 Help
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Do plugs and wires. Its not worth killing your catalytic converter or killing the rings in that cylinder from cylinder washing with raw fuel. Not to mention 20 other bad things that can be caused by an unchecked missfire. 6 cheap plugs at 2$ a piece and a 30$ set of wires will save you alot more money in the future. You dont want to end up like my buddy who drove almost 2k miles with a flat out missfire on cylinder 4. By the time he had me look at it the rings were completely destroyed and it had almost 0 compression on that cylinder. His cat and both 02 sensors were destroyed as well. The problem that caused this all? Plug wire got melted on his exhaust manifold. Car was crushed because it had over 300k on it. The other 5 cylinders had near perfect compression and the transmission felt perfect other then hesitating into 1st. Poor buick.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  20. #20 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    I got gas at the same place I always do. What's boggling my mind is that it was totally fine then 3 hours later I start it up and it's misfiring.
  1. Elusive cylinder 1 misfire(p0301)
    By upsman72 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2012, 10:15 AM
  2. Misfire in Cylinder 6
    By Porach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
