Thread: Blend doo or Blend door actuator?
Results 1 to 10 of 10
  1. #1 Blend doo or Blend door actuator?
    Feb 2010
    TN
    Just like it says guys, how can I tell if it's a blend door or a blend door actuator
  2. #2 Re: Blend doo or Blend door actuator?
    its the actuator, they turn the door.
    take them off turn the little knob by hand, hot is one way, cold the other. it only moves like a 1/2 inch, dont try to force it.
  3. #3 Re: Blend doo or Blend door actuator?
    Feb 2010
    TN
    So I need to buy an acutuator not a door scotty?
  4. #4 Re: Blend doo or Blend door actuator?
    you want a "blend door actuator". they are not cheap either. junk yard is the cheap/free even way to go. just grab 2 in case one dont work.
  5. #5 Re: Blend doo or Blend door actuator?
    Feb 2010
    TN
    anyone got a part number on this thing?
  6. #6 Re: Blend doo or Blend door actuator?
    go to a parts store web site and enter your cars info then search for the part. its easy.
  7. #7 Re: Blend doo or Blend door actuator?
    Feb 2010
    TN
    http://www.rockauto.com/catalog/x,ca...parttype,10721
    Ok which one of these dumb things do I ned to order?
  8. #8 Re: Blend doo or Blend door actuator?
    see how this one says w/manual controls. what do you have?
    DORMAN Part # 604107 More Info {#16177412, 5137781AA, 89018395, 89018681}
    Temperature Actuator (Controls the Blend of Hot and Cold Air); w/Manual Temperature Controls
    $26.79
    if you pull your bad one out, its got a part # on it. match it up to be sure. and once yours old one is out you can turn the knob to cold but it will be full time cold. no heat unless you turn it back to heat.
  9. #9 Re: Blend doo or Blend door actuator?
    Feb 2010
    TN
    I do have manula controls
  10. #10 Re: Blend doo or Blend door actuator?
    your lucky then thats the cheapest one they list.
  1. Blend Door Actuator Replacement
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-02-2017, 04:59 AM
  2. Blend door or actuator?
    By EJOUIE in forum General Tech Discussion
    Last Post: 05-05-2013, 11:00 PM
  3. Blend Door Actuator or Temp Controls?
    By lemkeant in forum General Tech Discussion
    Last Post: 04-23-2013, 07:04 AM
  4. Manually Turn Blend Door Actuator?
    By acidcrashdburnd in forum General Tech Discussion
    Last Post: 06-11-2012, 06:51 PM
