Thread: yet another E85 question...
Results 1 to 6 of 6
  1. #1 yet another E85 question...
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    After reading up and following the E85 threads over these past few months, I am confused on something:
    1) Does the stoich table in my 99 GTP actually work? I would think that I can just change the stoich table to that of E85 (around 9.85/1) and be done... Unless this table isn't used by the PCM, therefore I'd have to change injector flows?
    2) For my wideband, I have it set to read AFR.. so for gas, 14.7 at cruise, 11.0 at WOT, etc.. Wondering when I switch to E85, will it read 9.85 as that is what I am targeting at cruise conditions?
    I want to make sure I have all this understood, so that I actually know what I am monitoring when I switch over soon.
    Thanks!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: yet another E85 question...
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    subbed i want to know this too
  3. #3 Re: yet another E85 question...
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by jrb1027 View Post
    You running E85 yet in your GTP?
    2002 GTP sedan:
  4. #4 Re: yet another E85 question...
    Feb 2009
    flintnasty MI
    Stoich probably works but ive never tested it. There is no reason to mess with experiments when you can just change the injector table.
    Lambda is lambda regardless of the stoich numbers. All wideband number gauges come stock tuned for pure gas stoich readings vs lambda... if you run e85 1 lambda will be 9.85 afr but show 14.7 on the gauge.
  5. #5 Re: yet another E85 question...
    Mar 2014
    Cincinnati, OH
    Works for me! Thanks for the info Dark.
    2002 GTP sedan:
  6. #6 Re: yet another E85 question...
    Jun 2013
    brookville,IN
    Quote Originally Posted by 97AutoXVette View Post
    Not yet I have injectors and intercooler waiting to be put on im stoked that i finally found e85 available
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
