Thread: Idle voltage....Alternator?
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Idle voltage....Alternator?
    TDCRacing
    Guest
    True
  2. #22 Re: Idle voltage....Alternator?
    Before anything you should get yourself a good voltage gauge that plugs into the cigarette lighter, or a multimeter on the battery is best. The voltage gauges on the dash are a good indicator but never 100% accurate, often they can be out a fair bit.
  3. #23 Re: Idle voltage....Alternator?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    The way to test if it is alt.
    1. Test battery voltage at pos and neg
    2. Test voltage at the alt output, more then a half a volt difference you got a bad alt or bad wiring going to alt.
    On both test use the same ground point
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #24 Re: Idle voltage....Alternator?
    Jul 2008
    nj
    Quote Originally Posted by Toofastgs View Post
    I will check later today when I get home. I think the reason for my issue might be the 2 pumps going constantly with my headlights on at night. I rather find the issue prior to something dieing. Like TDRacing said, his has been like that for a year now. I just noticed it and I could be in the same boat
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  1. fuel pump voltage
    By theone2043 in forum General Tech Discussion
    Last Post: 11-10-2008, 01:35 PM
  2. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
  3. Alternator ????????
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-27-2008, 11:01 PM
  4. Grounding points // Voltage Drops...
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2008, 09:21 PM
  5. Alternator Voltage booster gone wrong
    Last Post: 03-19-2008, 03:44 PM
