Thread: Rocker Arm Bolt size and grade
Results 1 to 12 of 12
  1. #1 Rocker Arm Bolt size and grade
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    im gonna buy rocker arm bolts from a hardware store, instead of waiting on them to be shipped. Anyone know the size and grade of the bolt that comp cams offers?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: Rocker Arm Bolt size and grade
    Jan 2009
    Tallahassee, FL
    If you can't wait just get them from a parts store. If you use some hardware store bolts you're going to mess something up bad. Not to mention it's going to be a different metal than the stock bolts and so you won't have to correct torque if they would even work.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Rocker Arm Bolt size and grade
    Feb 2013
    Missouri
    I bought some from PRJ and they're better than grade 8 supposedly. I wouldn't use hardware store bolts, but I wouldn't use part's store bolts either since they're TTY. PRJ had them to me pretty quickly, so it was worth the wait for me.
  4. #4 Re: Rocker Arm Bolt size and grade
    Jan 2009
    Tallahassee, FL
    At least the parts store bolts are supposed to go in the car. I'd agree on the reusable bolts to
    77 Morris Garage B
  5. #5 Re: Rocker Arm Bolt size and grade
    Mar 2012
    Dallas
    you guys are over thinking this.. a bolt is a bolt. the grade of the bolt and size are what matter. i want non-tty bolts
    i will email zzp about it
  6. #6 Re: Rocker Arm Bolt size and grade
    Dec 2012
    troll land
    Prj?
    Quote Originally Posted by Booba5185 View Post
  7. #7 Re: Rocker Arm Bolt size and grade
    hangover park IL
    lol then all you need to do is go to ace (the only places around here that have any decent selection of bolts....)
    and pick up some 5/16ths coarse thread allen head capscrews with 2" UHL iirc
    ~James~ Psychotic Gearhead
  8. #8 Re: Rocker Arm Bolt size and grade
    Feb 2013
    Missouri
    Quote Originally Posted by l67ss View Post
    Prj?
    http://www.prjperformance.com/
  9. #9 Re: Rocker Arm Bolt size and grade
    Dec 2012
    troll land
    Kool thanks man
  10. #10 Re: Rocker Arm Bolt size and grade
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    We will help you fix your valvetrain in a few months when you pull the threads out of the head / have a rocker arm decide to go on vacation in the middle of a wot pull.... Seriously... Their are hundreds of differnt alloys and whatnot for a reason. One alloy might do great under high shear low load applications where the next alloy might do great under high load no shear applications. There is a reason that on crazy 4g63 1000+ horsepower builds people spend hundreds if not thousands on bolts / prepping the bolt holes for the cylinder head. You wouldn't use hardware store grade 8 bolts on your cylinder head would you? My guess is they will go in / torque down fine but they will snap off from heat cycling / the crazy high vibration / tension / torsion that rockers see. Or they will snap when you go to take them out.
    Edit. Something like this
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  11. #11 Re: Rocker Arm Bolt size and grade
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Be patient,why rush and cheap out now? Buy some comp cams or ARP reusable rocker bolts.
  12. #12 Re: Rocker Arm Bolt size and grade
    Mar 2012
    Dallas
    I got the comp cams bolts
  1. cam bolt socket size
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2013, 06:15 AM
  2. Rocker bolt help!!!!
    By DaytonaGTP500 in forum General Tech Discussion
    Last Post: 06-12-2012, 03:00 AM
  3. 97-03 GTP EGR tube bolt size?
    By AnotherGTP in forum General Tech Discussion
    Last Post: 01-25-2010, 11:27 PM
  4. Bolt size needed
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-13-2010, 10:27 AM
  5. Bolt Size
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2009, 06:40 AM
