Thread: Check Gas Cap???
Results 1 to 3 of 3
  1. #1 Check Gas Cap???
    Oct 2013
    North Dakota
    Im getting a message on the DIC that says "check gas cap" Ive had this problem for a while. I've used a scanner and i believe the code was "p0445". Anyway with my searches on the web (and 2 dealer visits) ive replaced the gas cap, the evap canister solenoid valve, and the fuel tank pressure sensor on top of the gas tank. The check gas cap message comes up after about 5 mins after i reset the codes (unhook negative battery cable) and the check engine light will come on a couple days later. What else am i missing? Is there a way i can bypass the system (with resistors or ???) Or how can i test each part of the system to determine the part at fault? Any help Appreciated.
  2. #2 Re: Check Gas Cap???
    http://engine-codes.com/p0445.html try changing the evap sensor on the back of the engine. its the one with a vac line on each side of the sensor.
  3. #3 Re: Check Gas Cap???
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    was the code p0455 by chance,
    what year/trim are you?
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. can someone check
    By fhaines in forum General Tech Discussion
    Last Post: 04-28-2012, 11:07 PM
  2. Check this
    By offroadfury6 in forum PCM Tuning
    Last Post: 08-22-2008, 12:23 AM
  3. Check this out.
    Last Post: 08-08-2008, 07:13 PM
