Thread: aeroforce interceptor install help
Results 1 to 3 of 3
  1. #1 aeroforce interceptor install help
    Jul 2013
    wyoming, michigan
    When hooking an aeroforce gauge to 12v power with add a circuit u only use ths red wire to do that right? I ran the red wire to my fuse box with add a circuit and had the jumper out and have it plugged into the obd2 port, but when I turn my car on the aeroforce doesn't turn on. Just wondering if I did something wrong. I used 22 gauge wire to connect it to the add a circuit and the wires the plug into the aeroforce and left the green and white wires unhooked to anything and I had the jumper out. Should I use diff gauge wire or plug into a certain spot in the fuse box? Its a 01 grand prix gtp.
  2. #2 Re: aeroforce interceptor install help
    You gotta use a 12v key on power source, so try like the radio or ignition fuse if you arent on one like that.
    White and green wires are fo add-on likes a wideband or something.
  3. #3 Re: aeroforce interceptor install help
    Dec 2012
    Canada
    I just hooked my Aeroforce up today and you need to remove the jumper if using the red 12volt power from the fuse box inside the glove box, best to use add a circuit and hook into switched power circuit, I used the power windows fused circuit and all is well, I now need to figure out how to set up and use this Gauge!
  1. Aeroforce interceptor
    By Anthony Smith in forum General Tech Discussion
    Last Post: 03-31-2013, 10:13 PM
