Thread: Thinking of converting to E85.. Yes or Ne??
Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 121 to 140 of 224
  1. #121 Re: Thinking of converting to E85.. Yes or Ne??
    Quote Originally Posted by SnowFlake View Post
    No problem, just ensuring that the correct information is disseminated.
    It's a shame your ego is larger than your base of knowledge
    That's induced as KR BTW.
  2. #122 Re: Thinking of converting to E85.. Yes or Ne??
    gardner,mass
    Im not second guessing anyone cus im unsure but im asking. Isnt that torque reduction during shift points in spark and fuel retard not timing? I thought kr was timing retard. Im lost on how that works exactly.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #123 Re: Thinking of converting to E85.. Yes or Ne??
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by Ginseng View Post
    KR is timing retard by the PCM from signals of detonation given by the knock sensors.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  4. #124 Re: Thinking of converting to E85.. Yes or Ne??
    Shayne, the way GM designed the pcm etc. They toss that amount say 2 degrees of retardation (removal of 2 degrees of timing) by injecting it as kr to decrease timing at the shift point in order to reduce power. As seen in the picture, it's dependent on the foot pounds of torque and the shift point.
  5. #125 Re: Thinking of converting to E85.. Yes or Ne??
    gardner,mass
    Thanks crb but thats not quite what i meant.
    Bill thats what i was looking for so basicly if im gradually accelerating the timing will be less adjusted during shift points by the pcm compared to if i was full throttle?
    Does this apply to say going up hill or down hill in both equations? Cus i imagine more load= more torque needed going up hill= more retard? If this makes sense lol
    Edit: What im getting at is i wont really see any kr when i first get my car to operating temp and start gunning around. When i have been driving the car awhile and my trans temp get up to say 180-200 i will start seeing knock. That knock will raise further when going up hill.
    Is this due to the added friction in the trans from being so hot? Causing more load on the engine, and causing more torque needed from the engine because of?
  6. #126 Re: Thinking of converting to E85.. Yes or Ne??
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    damn GM and their pcm's, i dont need any more retardation tossed at me!!!!! im retarded enough LOL
  7. #127 Re: Thinking of converting to E85.. Yes or Ne??
    gardner,mass
    ^LOL^
  8. #128 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Quote Originally Posted by danomite02 View Post
    I concur..
  9. #129 Re: Thinking of converting to E85.. Yes or Ne??
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    hey crb, so you filled up with e85 and your car ran fine without having to make tuning adjustments? bc im gonna swap soon and was wondering how i could get 100% e85 by the time i get it tuned and have the fuel filter changed and ready to go.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  10. #130 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Quote Originally Posted by TEK310 View Post
    Correct.. Just fill her up and make sure you don't hit the skinny pedal too hard LOL. Naw, you'll be fine, just noooo boost until you tune!
  11. #131 Re: Thinking of converting to E85.. Yes or Ne??
    Mar 2012
    Dallas
    okay, sweet. thanks
  12. #132 Re: Thinking of converting to E85.. Yes or Ne??
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Sorry to bring up the whole timing debate again.... Iv been gone from the forums for a while and haven't had a chance to pipe in. One thing you guys have to remember is that I am running a high compression setup.... Higher compression = me hitting peak combustion in a shorter amount of time. I need less time before TDC to reach peak combustion. I rolled into the dyno session with a 3.8" pulley, 230whp, and 19* of timing. Left with 15* of timing, a 3.6" pulley, and 260 ish whp. On a low compression setup I have NO DOUBT WHATSOEVER that more timing would be very beneficial. Now on e85 you do get more headroom to add timing if you arent already at your maximum useful timing. So if you are still rocking stock timing by all means take advantage of the additional octaine and crank the timing up.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  13. #133 Re: Thinking of converting to E85.. Yes or Ne??
    Feb 2009
    flintnasty MI
    I have never found this. All of my transmission tuning shows directly in timing, not with any KR in all 97, 98, 99-01.5 and 01.5-03 code bases.
  14. #134 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    There is no such thing as KR programmed by the PCM to reduce torque on shifts. The PCM retards timing independent of the knock detection system.
    KR is a direct result of noise picked up by the knock sensors in a certain frequency range. There is only knock, and false knock... there is no "programmed knock" for torque management.
    You don't have to agree with me, you can just be wrong.
    The small blips that Chris is seeing (under 1*) are likely from noise being picked up somewhere else... not from actual knock/detonation.
    The characteristics of real knock are opposite that of false knock.
  15. #135 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    I always thought the blip of KR I get at shift point here and there was false KR because sometimes it happens and sometimes not. It also occurs as the tranny shifts not pre shift. If the PCM was doing it wouldn't it happen every time I went wot? Not trying to contradict anyone's claims here, it is just what I've noticed with my own application.
  16. #136 Re: Thinking of converting to E85.. Yes or Ne??
    LOL, I've admitted to being wrong etc many times. It's called being humble, when you learn it ... let us know. Til then you may want to consider browsing the FSM on the info you are speaking about. You can't find the term "False knock" in the manual, because false knock isn't a real item. It's a mechanical issue that needs to be fixed.
  17. #137 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    False knock is when the knock sensors pick up on a noise in the same frequency range as real knock, but knock never actually occurred.
    It's my goal to ensure that people can find and read information that is both relevant to the topic and correct.
    What you're propagating is irrelevant and false.
    Chris, your car isn't "knocking" during the shift because of the torque management. I hope you understand this concept is ridiculous.
  18. #138 Re: Thinking of converting to E85.. Yes or Ne??
    Nick, post some proof.
  19. #139 Re: Thinking of converting to E85.. Yes or Ne??
    gardner,mass
    Again im just trying to understand this. The timing retard programmed in the pcm during shifts is torque management to save the trans life not to combat knock?. But does or doesnt show on a scan gauge as actually kr? If it did i imagine everyone would see kr during shifts but not everyone does. But i thought the scan gauges read timing retarded in degrees to combat knock. Now is kr on a gauge reading retard only during actually knock or false knock? or is it reading the actual knock or false knock thats accuring in degrees? Now its possible gm programmed that retard to combat knock that is more probable during shifts.
    Edit: So if we took those values of what bill posted and set to zero would the car be more prone to knock or would it just put more stress on the tranny?
  20. #140 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Edit: So if we took those values of what bill posted and set to zero would the car be more prone to knock or would it just put for stress on the tranny?
    What Bill is saying is confusing an issue that really isn't even an issue.
    The torque management system is just that... torque management. It has nothing to do with knock.
    KR is either knock, or something else making noise that falls within the frequency range of knock.
    This is 3800 101 here.
    I'm sorry you guys are being confused by Bill.
    This is a decent write up that seems relevant.
    http://www.zzperformance.com/blog/ab...ock-retard-kr/
  1. converting
    By cmn36 in forum General Tech Discussion
    Last Post: 01-15-2011, 07:18 PM
  2. converting a 01 to an 04
    By sasquatch094 in forum General Tech Discussion
    Last Post: 03-25-2010, 05:22 PM
  3. Converting to supercharged
    By Bechtel88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 09:31 AM
  4. question on converting.
    By gt42lst in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 11:54 AM
  5. Converting from a 1 bar to a 2 bar map.
    By TurboKent in forum General Tech Discussion
    Last Post: 03-16-2008, 02:10 PM
