Thread: Thinking of converting to E85.. Yes or Ne??
Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 224
  1. #61 Re: Thinking of converting to E85.. Yes or Ne??
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by tms8582 View Post
    My friends 01 Gtp Daytona 500 has a metal tank btw. Just sayin check it out
    I checked and it is a plastic tank. Since swapping the power source of my rewire from the fuse box to the alternator it seems to have helped a bit. Now at WOT, the car is a low-11's AFR until about 5500rpm, and then slowly creeps up to a low 12's AFR (12.2 max at shift point). I'm going to replace the filter just for kicks. One thing I noticed is that my LTFT's are now mostly in the negative. When cruising they go as low as a -17.1, but then back to 0 at WOT. I was told they should be +/- 10 at the most, so maybe that has something to do with it.
    Regardless, I have heard of guys running mid 12's for an AFR with E85, so I think it can still be tuned well enough.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #62 Re: Thinking of converting to E85.. Yes or Ne??
    Chris..
    If you need some braided lines instead of the plastic, LMK A local just took his off his car as he parted it out. I'm sure he'd be willing to sell.
    Also on the rewire going to the alternator, you may want to move that over to the battery. The battery is your more consistent power source. The alternator is turned on and off by the pcm based on certain parameters. Like being under 600ish rpm etc. If you wanted to ensure the best source, I'd run a big 3 setup that feeds from alt to batt and fuse box and connect the FP to the batt.
  3. #63 Re: Thinking of converting to E85.. Yes or Ne??
    Feb 2009
    flintnasty MI
    I target AFR in the mid 12s and dont get scared if I see 13s on e85. Keep timing low.
  4. #64 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    I want my afr to run in the mid 11's so I can safety drop a pulley and/or ad more timing. The problem is it keeps leaning out into the mid 12's come the 6200rpm shift point and I can't figure out why.
  5. #65 Re: Thinking of converting to E85.. Yes or Ne??
    Feb 2009
    flintnasty MI
    Quote Originally Posted by crbquist View Post
    sigh.
  6. #66 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    I told you why lol
    DH keep your yapper shut...
  7. #67 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    I meant I knew it was a pressure issue just didn't know where. Well, I emailed PRJ and he said to check the hose connection in my fuel pump to make sure it is tight enough. I pulled the pump this afternoon and discovered that the module hose was not fully connected to the top of the canister. There was about a 1 cm gap. Let's just say problem solved! My AFR is now at about an 11.7 max at shift point (6200rpm), and I no longer have hard starts. The pump was bleeding off pressure.
  8. #68 Re: Thinking of converting to E85.. Yes or Ne??
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I run it every day... Its awesome. It smells good. You can run lots of boost. Its much more forgiving (Less likely to knock a piston out if you go lean).
    It also sucks if you cant find a station and you car WILL start funny in the cold. It will always start but it will be a bit cranky about being woken up in the cold. Mine even started on a -35* day last winter. It took about 5 full secconds of cranking and then a little throttle to stop it from chugging but whithen 15 seconds it smoothed out and was happy as a clam.
    Worried about not being able to find it in a pinch? I bought a mini afc and if I cant find e85 I just pop the mini afc inline with my maf. Scale it back 25%. And then Swap 2 or 4 pulley sizes up. Takes about 5 mins when you have the 5mm hex wrench, 15mm wrench, and pulley in the trunk. I only had to do it once when I drove all the way down to empty to this station that supposedly had e85 but found out they did not.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  9. #69 Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    sigh.
    Why would you want to keep timing low? You can run more timing and boost with E85 due to it burning a lot cooler than 93.
  10. #70 Re: Thinking of converting to E85.. Yes or Ne??
    Feb 2009
    flintnasty MI
    Flame front propogation and the fact that anything passed 15 or 16 is beyond MBT. You might want to make up for timing creep with some fancy stuff, but I wouldnt attempt it without a dyno and some knowledge.
  11. #71 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    I think you just like hearing yourself talk.
    Chris' car is in good hands <3
  12. #72 Re: Thinking of converting to E85.. Yes or Ne??
    May 2012
    Pittsburgh
    From my limited experience with E85, it seems to prefer boost-heavy combinations vs advancing timing. The cooling effect on the charge really is conducive to adding boost and the results are usually spectacular. Not sure why, but they don't seem to respond as well to added ignition timing vs gasoline stuff.
    Active Roster: 2006 Grand Prix GT - Supercharged/Intercooled 2005 Mustang GT - 2012 Impala LT
    Injured Reserve: 2000 Regal GS - 1993 Mustang LX
  13. #73 Re: Thinking of converting to E85.. Yes or Ne??
    Apr 2011
    South Dakota
    I agree. When I run 20* of timing and a 3.0" Pulley my car does not feel NEARLY as quick as my 2.8" pulley and 14 - 15* of timing.... though I am running high compression so peak combustion is reached much much sooner. This was also proven on the dyno that no gains were had above 15* of timing on my setup.
    I love Decker<3
  14. #74 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Quote Originally Posted by frosty View Post
    I'd be interested to see these dyno plots.
    Can you produce them?
  15. #75 Re: Thinking of converting to E85.. Yes or Ne??
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    That is interesting. When we dyno tuned my old setup, when i switched over to e85, it was only past 22* that the power increase became negligible. That was 17psi.
  16. #76 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    There will be no dyno plots demonstrating his statements.
  17. #77 Re: Thinking of converting to E85.. Yes or Ne??
    Timing vs Boost vs Fuel Type
    Yes we need more info who's got it?!!!!
    Anyone know if OrangeL67's build was on E85 that thing ripped for pretty mild mods.
  18. #78 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Just to be clear... Danomites car made almost 25whp more with added timing over 15*... on e85.
    I stopped at 21.5* of timing. That's 6.5* over 15* for 25whp...
    Anyone who thinks that timing above 15* produces negligible gains is simply wrong.
  19. #79 Re: Thinking of converting to E85.. Yes or Ne??
    Need to compile a spreadsheet or something
    Timing / Boost / Fuel type / Dyno numbers
    This could get really interesting real quick.
  20. #80 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    As I recall it was on E85.
  1. converting
    By cmn36 in forum General Tech Discussion
    Last Post: 01-15-2011, 07:18 PM
  2. converting a 01 to an 04
    By sasquatch094 in forum General Tech Discussion
    Last Post: 03-25-2010, 05:22 PM
  3. Converting to supercharged
    By Bechtel88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 09:31 AM
  4. question on converting.
    By gt42lst in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 11:54 AM
  5. Converting from a 1 bar to a 2 bar map.
    By TurboKent in forum General Tech Discussion
    Last Post: 03-16-2008, 02:10 PM
