Thread: New codes nice lol....
Results 1 to 14 of 14
  1. #1 New codes nice lol....
    Dec 2010
    DMV
    First up its the po171 code. I believe that is the lean code. So right now I'm hunting down vacuum leaks. Any ideas?
    Next is the po306 cylinder six code.
    Little background, these codes popped up after reinstalling my Supercharger after painting it.
    At first the car was missing horribly so I peeked around and pushed the injector above cylinder down more and the misfiring stopped.
    After that It drove fine. Still drives fine. The code pops up every so often. I think when I go wot the code appears.
    Ok just scanned N got history misfires on cylinder 2 4 and 6.
    Cylinder two has like 12 misfires
    Cylinder four has like 144 misfires
    And cylinder 6 has a whopping 1635 misfires.
    Any idea As to what is going on?
    Also I moved my wires from on top of the charger for a cleaner look and reinstalled them at the coils. Maybe I didn't install them the right way?
    Any help is appreciated!
    Sent from my HTC One using Tapatalk 2
  2. #2 Re: New codes nice lol....
    Dec 2010
    DMV
    Here's a pic to my history on my app
  3. #3 Re: New codes nice lol....
    St. Louis
    I'd start at the "T" under the snout and go from there. Def. sounds like a vac leak for the lean code.
    I'd double check the firing order and your wires too. It happens all too often, even when you swear you got them on the right cylinders.
  4. #4 Re: New codes nice lol....
    Dec 2010
    DMV
    Ok great
  5. #5 Re: New codes nice lol....
    Kansas
    IMHO if you are getting a lean code.... running WOT is just plain stupid and monitoring it with Torque. I would track down why number 4 and 6 are misfiring. As you are getting misfires on cylinder 2,4, and 6 which are all on the same bank... makes me think fuel rail. I would suggest pulling your fuel rail off, check all the o-rings, and try reseating it. The fuel rail might have got slightly bent that is un-noticeable, but very likely. As the misfires seems to increase from left to right, my guess is the rear right of the rail is still way off.
  6. #6 Re: New codes nice lol....
    Dec 2010
    DMV
    Actually never go wot in my Car, had to do it today to avoid some idiots. Seems logical though. Might try that tomorrow. What's the easiest way to reseat them? I had quite the time getting them to reseat.
  7. #7 Re: New codes nice lol....
    Dec 2010
    DMV
    Update.
    Thinking back I noticed that cylinder six injector had a circular disk plate on it. While cleaning it I kinda broke it lol. So could that be the issue?
  8. #8 Re: New codes nice lol....
    Those little disc plate things are just they to hold the o-ring in place, they arent even needed as the o-ring sits in a "indent" on the injectors and wont fall off.
    I say either the gasket you got was junk or something wasnt super clean, or the injectors arent fully seated or you broke a vacuum line,
  9. #9 Re: New codes nice lol....
    Dec 2010
    DMV
    I can spray around with carb cleaner right with no ill effects right?
    Even by the injectors?
  10. #10 Re: New codes nice lol....
    Yeah you can, but you might not notice a change in rpms.
    You'd notice a change in short term fuel trims though if you had a scanner to watch them. Or if you had a smoke/fog machine to run through the vacuum lines.
  11. #11 Re: New codes nice lol....
    Dec 2010
    DMV
    Well I have my torque app, it shows the long term and short term fuel trims. Could I use that?
  12. #12 Re: New codes nice lol....
    My money is on injector o rings
  13. #13 Re: New codes nice lol....
    Dec 2010
    DMV
    Anyone else would like to place some bets? Also, how can I get this Damn rail to seat properly? Front? Easy peasy. Back? Smh I couldn't get it right did the best I could lol.
  14. #14 Re: New codes nice lol....
    Dec 2010
    DMV
    Update!
    Injectors weren't seated correctly and the tee under the snout was cracked.
    All is well now
  1. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  2. well this is nice
    By dpzelenak in forum Off Topic Discussion
    Last Post: 07-31-2011, 08:50 PM
  3. You know its a nice day if you can...
    By jcmonteman in forum Off Topic Discussion
    Last Post: 04-09-2011, 06:37 PM
  4. Oh well is'nt that just nice...
    Last Post: 01-01-2009, 07:25 PM
  5. WOW....These are nice!
    By TDCRacing in forum Off Topic Discussion
    Last Post: 06-15-2008, 10:08 AM
