ADrugDealer
Schooner Tuner
So car runs great in low RPM and under normal driving conditions and even under lightly spirited driving; however, when I go wot, right before I hit 6250RPM (shift point), the car goes into limp home, with no throttle response at all. DIC says "Check traction control" "Check abs" "reduced engine power" and the code P0068 is thrown.
I used my aeroforced to log the event, Maf HZ hit 11025hz (Lq4 maf), 0* KR. 6200ish RPM, 186* Coolent, normal conditions, minus the whole limp home part.
Car is an 04 GTP w/ headers, XP Cam, E85, ZZP full stack IC, 2.8SC pulley, LQ4 maf.
I have a mini AFC sitting at home NOT INSTALLED (6 hours away, I'm at college now, but can get it sent to be fairly easily).
Any hints?
Any hints?
