Thread: Washer Fluid Hose Replacement
Results 1 to 5 of 5
  1. #1 Washer Fluid Hose Replacement
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    Anyone know the length of the washer fluid hose for a 2004 GP? Mine has cracked in like 10+ spots and while I can patch it with a larger hose around it, it's getting to be quite annoying. I want to replace the hose now but measuring the length is annoying, but do able.
    Outside of that, does anyone know how to access the back of the washerfluid pump so I can disconnect the hose? I figured I could try from the passenger wheel well, I hope I don't need to take off the entire front bumper.
    I'm probably going to buy replacement hose from AutoZone of AdvanceAutoParts, or some other similar place if I can find the length I need. I believe the diameter is 5.5mm or 7/32''. Thanks for any help.
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  2. #2 Re: Washer Fluid Hose Replacement
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    junkyard for probly 2$
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  3. #3 Re: Washer Fluid Hose Replacement
    I live here. DirtDog's Avatar
    Jun 2012
    You can access it through the wheel well. You'll just have to remove the well linear. Its held on by a bunch of 10mm bolts
  4. #4 Re: Washer Fluid Hose Replacement
    Nov 2009
    I'll remove the liner, that's how i thought I could get to it but wasn't 100%. I'll measure with a string the length and buy replacement hose from an autoparts store. I think if i used a junkyard part it would have just as much sun damage as my current hose has.
  5. #5 Re: Washer Fluid Hose Replacement
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by UCF04GPGTPCompG View Post
    when I bought my 07 it came broke, so I took a oem off a 01, works great
    but I do hear what your saying, even at a part store cost is minor
  1. low washer fluid pressure?
    By Adasm in forum General Tech Discussion
    Last Post: 12-30-2012, 05:37 PM
  2. Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 07-07-2012, 03:10 PM
  3. winshield washer hose
    By JoeC9107 in forum General Tech Discussion
    Last Post: 09-14-2010, 06:44 PM
  4. Low Washer Fluid
    By ericrluoma in forum General Tech Discussion
    Last Post: 09-17-2009, 11:11 PM
  5. Windshield Washer Fluid
    By Pontiac99GTP in forum General Tech Discussion
    Last Post: 09-09-2009, 01:35 AM
