Thread: Fuel Pump Installation
Results 1 to 7 of 7
  1. #1 Fuel Pump Installation
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    I'm installing a new AC Delco fuel pump tomorrow and was wondering if there is any special tools or tips you guys could offer. I already checked the fuse and tried the relay bypass. They did not work. I am hoping this will go as smooth as possible since I will be starting school in a few days and need the car to get there. Any feedback is appreciated. Thanks
  2. #2 Re: Fuel Pump Installation
    Ohio
    You replacing just the pump? Or the whole assembly?
  3. #3 Re: Fuel Pump Installation
    dont forget there is a lock on the top of the fuel door...
  4. #4 Re: Fuel Pump Installation
    Apr 2009
    Upper Darby, PA
  5. #5 Re: Fuel Pump Installation
    Apr 2009
    Upper Darby, PA
    Quote Originally Posted by gtpsleeper View Post
    The snap ring around the top of the pump?
  6. #6 Re: Fuel Pump Installation
    For those who wanted to know, its a 97 GTP. I looked at his profile.
    Pull the carpet back, remove the 8 or so cover bolts to get at the fuel pump.
    Unplug the connectors and remove the quick connect fuel lines and its either a snap ring or a lock ring that will hold the pump in place. Remove it, pull the pump up, let it drain for a minute or two, take it out and drop the new one in its place. Plug everything back in and turn the key and hope thats your problem fixed.
  7. #7 Re: Fuel Pump Installation
    Apr 2009
    Upper Darby, PA
    Thank you guys for all the help. It went very smooth. Once I got the new pump in it started up right away. Thanks again.
  1. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  2. Fuel Pump Installation
    By Burbman in forum General Tech Discussion
    Last Post: 12-08-2012, 09:11 AM
  3. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  4. Fuel Pump Installation
    By Sipes in forum General Tech Discussion
    Last Post: 07-21-2010, 12:25 PM
  5. Water Pump Installation Question
    By Lawngoose in forum General Tech Discussion
    Last Post: 12-07-2009, 09:52 PM
