Thread: XP cam or 1.9 roller rockers
Results 1 to 18 of 18
  1. #1 XP cam or 1.9 roller rockers
    Jun 2013
    Hollywood ,FL
    what up so im in a pickle now not sure whether I want to buy a cam or some rockers. Im good with mechanics but don't know about taking my daily driver apart lol my goal is to hit high 12s low 13s in time so I really want to know is how many of yall actually installed your cam yourself? Or how many paid a shop to do it if so how much and what kind of shop are they? I know I can put in rockers myself but cam seems more extensive I would be keeping the motor in the car due to that I don't have a cherry picker. Not sure if I can hit high 12s low 13s with 1.9 rr and a stage 2 intercooler
  2. #2 Re: XP cam or 1.9 roller rockers
    Banned
    CT
    To compare 1.9 rockers to an XP cam would promote the false notion that the two are comparable.
    XP cam is better and there is no comparison.
  3. #3 Re: XP cam or 1.9 roller rockers
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    doing the cam in the car is not difficult at all. It can be done in a weekend by a slow guy, or a long afternoon by a mechanically inclined person. Just make sure you disconnect the int steering shaft before you drop the cradle
  4. #4 Re: XP cam or 1.9 roller rockers
    Jun 2013
    Hollywood ,FL
    have you done a cam swap yourself a lot of ppl say its easy and have never done it by the way I have an 05 gtp now sure if that matters now when I line up the timing marks on camshaft gear and crank pulley is there anything else you have to do dial in anything as far as degrees for timing? Ive been told dropping in jus the rolles and a pulley drop ill be happy for the st like I said I want to know the simplest cheapest way to hit low 13s high 12s besides using nos I want the power too always be there
  5. #5 Re: XP cam or 1.9 roller rockers
    Banned
    CT
    Quote Originally Posted by kurupt305 View Post
    Between danomite and I... there's been a few cam swaps done LOL
  6. #6 Re: XP cam or 1.9 roller rockers
    Jun 2013
    Hollywood ,FL
    I tell you what man it would be awesome to have someone to help me here in south florida but the only guy I know says doing a cam isn't worth it for the price and head ache to just do the 1.9 rr he told me to just go turbo lol ;( ir to do the rockers
  7. #7 Re: XP cam or 1.9 roller rockers
    Jul 2011
    CT
    well of course turbo is the way to go, but you certainly wouldnt be disappointed with an xp cam. mine took me to 356whp. I am 100% certain rockers wont get you anywhere close to that.
  8. #8 Re: XP cam or 1.9 roller rockers
    Jun 2013
    Hollywood ,FL
    how mechanically inclined were you when you did that also what mods did you have to get you that hp?
  9. #9 Re: XP cam or 1.9 roller rockers
    Cam > rockers any day of the week
    04 Comp G.
  10. #10 Re: XP cam or 1.9 roller rockers
    Jul 2011
    CT
    well i was a GM tech for a while. On one of the in car cam swaps i/we did, i was just there to help out a novice. Did it in a long afternoon. Id swear there has to be a write up for this for you to use as a guide. And there are plenty of people here that would be more than willing to help walk you thru any hiccups you may encounter.
    previous mods were: IS 2.5 heads, gen V w 2.6, fsic, full exh, e85+meth injection, every and all supporting mods.
  11. #11 Re: XP cam or 1.9 roller rockers
    Jun 2013
    Hollywood ,FL
    I know cam over rockers but for the money and hp and ease of installation yourself and parts and what not is it really worth it
  12. #12 Re: XP cam or 1.9 roller rockers
    A bit of info from me...I thought the same thing and bought a set of used modified 1.9 some years ago think hey rockers are a easy install and I should be happy...wrong. Wasn't impressed by the gains and wanted more..at this time I found a use low mileage vs cam and thought what the hell. Sold those 1.9s and bought the VS for the same. It's not to much more work and the additional parts aren't expensive.
    If you were to do rockers you would want to do springs, valve seals, vc gasket if yours aren't in great condition.
    Cam.. Valve springs, valve seals, vc covers, coolant elbows, oil , timing chain and dampener I'm sure I'm missing something but that's the basics of what you need.
    Did my cam install in a few hours in my driveway..no fancy tools or anything just simple sockets, breaker bar, beer.
    04 Comp G.
  13. #13 Re: XP cam or 1.9 roller rockers
    Jul 2011
    CT
    Have a couple buddies over for moral support LOL, and like he said^ BEER
  14. #14 Re: XP cam or 1.9 roller rockers
    Jun 2013
    Hollywood ,FL
    comp g do you still have the vs how much more of an better increase in power did you feel over rockers also on avg what did you spend with all parts
  15. #15 Re: XP cam or 1.9 roller rockers
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    I'm like 99% sure that Billboost has a write up
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  16. #16 Re: XP cam or 1.9 roller rockers
    I never dyno'd or tracked it to give accurates number but it was quite a noticeable difference. I preferred having power in the low to mid rpm range since I was city driving a lot vs the rockers that seem to only give more power at the higher RPM range. I still have the VS in the car now fixing a few things and getting ready to hopefully put in back in the road here's in the next few weeks.
    -$200ish for cam
    -$35 for valve springs and retainers
    - timing chain, dampener, valve seals, vc got from advance and I tend to abuse the whole coupon code thing and pick up in store vs buying from ZZP.
    -$12 for beer <<<< very important, very important.
    - I also pulled the heads when I installed the valve springs and dropped the heads off at the machine shop to have them checked for cracks, decked, etc etc..wasn't needed but I figured why not. (New headgaskets as well)
    04 Comp G.
  17. #17 Re: XP cam or 1.9 roller rockers
    Spring Lake, Mi
  18. #18 Re: XP cam or 1.9 roller rockers
    04 Comp G.
  1. roller rockers.....help....plz
    By bigdawg15005 in forum General Tech Discussion
    Last Post: 09-13-2009, 03:22 PM
