Thread: Electrical issue when I shut off my car.
Results 1 to 4 of 4
  1. #1 Electrical issue when I shut off my car.
    SE Level Member YZ250rider's Avatar
    Aug 2012
    Sioux Falls, SD
    I'm having a problem when i shut off my car and my battery dies. Sometimes it turns on right away, sometimes it doesn't. It will keep me from pulling the key out too. I've closed my door a couple times and it turns back on but everything is reset. I don't know what's going on. I figured there had to be a short somewhere. Anyone know?
    Vehicle is a 1998 Grand Prix GTP
  2. #2 Re: Electrical issue when I shut off my car.
    I would clean all the engine grounds and disconnect the battery and clean all the connections.
    Makes sure none of them are damaged.
  3. #3 Re: Electrical issue when I shut off my car.
    Aug 2012
    Sioux Falls, SD
    Stupid question: where are all the engine grounds?
  4. #4 Re: Electrical issue when I shut off my car.
    Dec 2012
    Where 4T65E's were born
    There is one where the engine and trans meet, right up front. I believe it's a 15mm but not sure. The main frame ground will be right off the negative battery terminal, can't remember that size off hand. Anyway just take them off and use a little wire brush and clean up the surfaces on the frame/block and the ring terminal.
    Sold.
  1. Random Shut off issue
    By PrixOwner in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-22-2013, 04:28 PM
  2. new electrical issue on 02
    By powdercoater46 in forum General Tech Discussion
    Last Post: 09-02-2011, 05:41 PM
  3. VERY ODD electrical? issue
    By Pittman06 in forum General Tech Discussion
    Last Post: 01-18-2010, 07:30 PM
  4. electrical issue
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 12-10-2009, 10:49 PM
  5. 98 GTP, Electrical gauges and stereo and all that erase every time i shut the car off
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2009, 12:46 PM
