Thread: Rocker Panel Dimensions
Results 1 to 4 of 4
  1. #1 Rocker Panel Dimensions
    May 2013
    PA
    Hello, Just wondering if anybody has dimensions with bend angles of the rocker panels for the 98 Grand Prix. I can get the dimensions off mine fairly easy, determining the angles will be a little bit of a PIA. I only need a small section of sheet metal, so I am just going to have something made up. Any help would be greatly appreciated!! Paul
  2. #2 Re: Rocker Panel Dimensions
    SE Level Member Thinksun's Avatar
    Sep 2012
    GTP Ontario
    I bought the basic aftermarket rocker panel and cut it to length to fit. For $30 I got enough to do both sides, cant be less for a custom made piece.
    http://www.andysautosport.com/pontia...t00000165.html
    1997 GTP .
  3. #3 Re: Rocker Panel Dimensions
    SE Level Member KitRae's Avatar
    Jul 2012
    St. Catharines
    Quote Originally Posted by Thinksun View Post
    Was this for a 2 Door or 4 Door? Just want to make sure I order enough and not Too Much. LOL.
    Stupid Rocker Panels! I would leave them off if it wasn't for passing Safety.
    2002 Grand Prix GT 3.8L Naturally Aspirated
    - NGK Iridium Performance Spark Plugs
    - NGK 51031 Performance Spark Plug Wires
    - EPR Cross Drilled Performance Brakes & Ceramic Pads
  4. #4 Re: Rocker Panel Dimensions
    Sep 2012
    GTP Ontario
    They are the universal ones for a 4 door, I adjusted length as I needed for mine to replace damage- which is a 2 door. 2 and 4 door have same wheelbase and panel section goes wheel well to ww. These units dont have sills on them so they work perfect for rust repair, cut them to length and notch as required. I see your in London, just go to an auto parts store (even partsource-last resort) and order universal rocker panel replacement just like in the picture in link above- they order from Keystone/Cross-Canada. I get discount and they were $30, ask for a cash account discount- tell them you will be back to order lots of parts as you have a Grand Prix and they should offer you garage pricing.
    I glued (auto panel adhesive) and pop riveted mine on using 3/16 rivets ( have an air riveter from Princess Auto). I also have a mig welder and this is a faster and structurally sound repair. http://www.levineautoparts.com/maxim814.html
    Keystone http://ecat.crosscanadaparts.com/bas...p?go=exprorder
    1997 GTP .
  1. Rocker Panel Problems!!!
    By Baileyracing in forum General Grand Prix Discussion
    Last Post: 07-14-2012, 02:48 PM
  2. rocker panel issues
    By stok3z in forum General Grand Prix Discussion
    Last Post: 04-25-2012, 04:25 PM
  3. I got new rocker panel moldings!!!!!!!!!!
    By Doug 97 gtp in forum Visual/Body Modifications
    Last Post: 04-24-2012, 12:11 AM
  4. anyone know there to buy new rocker panel moldings
    Last Post: 01-06-2012, 03:18 PM
  5. rocker panel replacement??help??
    By brian91z34 in forum General Tech Discussion
    Last Post: 02-23-2009, 09:23 PM
