Thread: weird electrical problem?
Results 1 to 13 of 13
  1. #1 weird electrical problem?
    Apr 2013
    Michigan
    so i went to turn my car on after work and it turned on like normal, but then the guages started acting weird and it shut off. it turned back on and i got it home but im just curious why something like that would happen. its not the first time something like this happened, like i would go to turn it on to listen to the radio or something without turning the engine on and it would shut off and then work fine. any ideas? its a 97 gt if that makes any difference lol thanks
  2. #2 Re: weird electrical problem?
    St. Louis
    Check the battery cables and make sure they are clean and tight.
  3. #3 Re: weird electrical problem?
    Dec 2012
    Where 4T65E's were born
    ^ do that and check/clean grounds. Also was it all gauges or just the tach?
    Sold.
  4. #4 Re: weird electrical problem?
    Apr 2013
    Michigan
    i didnt really see anything besides the tach doing it but i didnt look at the others when it was happening lol
  5. #5 Re: weird electrical problem?
    Dec 2012
    Well if the tach dropped, then very shortly after it stalled, that is the result of a bad crankshaft position sensor.
    Sold.
  6. #6 Re: weird electrical problem?
    Apr 2013
    Michigan
    i see. i have no idea lol recently when i went to roll my windows up or down the dome light flickered so im just curious whats going on lol
  7. #7 Re: weird electrical problem?
    Dec 2012
    Dome lights may dim, but shouldn't flicker. That adds another clue to check grounds. Engine ground is where the engine/trans meet in front, and main ground is right off the neg battery terminal.
    Sold.
  8. #8 Re: weird electrical problem?
    Apr 2013
    Michigan
    well yeah it dimmed not flickered
  9. #9 Re: weird electrical problem?
    Dec 2012
    Alright but cleaning grounds is easy, just need sockets and a wire brush.
    The crank sensor may stall your engine at any time, often it will stall and start right back up, or some make you wait until it cools a bit. Not fun.
    Sold.
  10. #10 Re: weird electrical problem?
    Apr 2013
    Michigan
    well the car started perfectly fine, just after i started to drive off the guages started to take a **** and it shut off lol
  11. #11 Re: weird electrical problem?
    Mar 2013
    Tionesta Pa.
    I had the same problem and mine ended up being the ground wire coming off the battery to the block.
  12. #12 Re: weird electrical problem?
    Pennsylvania, USA
    Check your grounds and battery as stated, and test the crank sensor (I think there's a way to test them with a multimeter).
    If those aren't it, then I'd bet it has to do with your ignition switch or cylinder, whatever it's called. The thing you put your key into. My gauges would randomly stop working for a while and I'm almost certain it's corroded connections in my ignition switch.
  13. #13 Re: weird electrical problem?
    Dec 2012
    Quote Originally Posted by nik12937 View Post
    ^ another possibility. Update this thread, and/or let us know if you found the problem.
    Sold.
  1. HELP weird electrical problem
    By Rkrajnov in forum General Tech Discussion
    Last Post: 03-30-2013, 05:16 PM
  2. Weird electrical problem
    By ls1camino in forum General Grand Prix Discussion
    Last Post: 03-01-2013, 08:56 PM
  3. weird electrical issues
    By asite57 in forum General Tech Discussion
    Last Post: 07-08-2012, 09:49 PM
  4. Weird Electrical Issues
    By tdm571 in forum General Tech Discussion
    Last Post: 03-15-2011, 09:34 AM
  5. Weird Electrical Issues
    By Dabman in forum General Tech Discussion
    Last Post: 03-02-2011, 05:35 PM
