Thread: Air Conditioner issue: Evaporator Tube Assembly needs to be replaced.
Results 1 to 4 of 4
  1. #1 Air Conditioner issue: Evaporator Tube Assembly needs to be replaced.
    SE Level Member GT in Kennesaw's Avatar
    Kennesaw, GA
    The high-pressure valve on the air conditioner of my 01 Grand Prix started leaking and needs to be replaced. Unfortunately the Schrader valve is not replaceable on the high-pressure side. The entire Evaporator Tube Assembly must be replaced. I got the part (Amazon) and started to disassemble but can't seem to figure out how to pull it out without pulling the engine first. There's a coupling that is located under the break booster but I can't get any tool I own on it to take it apart. Has anyone ever tackled this job before? Need help.
    Thanks.
  2. #2 Re: Air Conditioner issue: Evaporator Tube Assembly needs to be replaced.
    It's possible, sucks, but possible.
    Go in through the wheel well and undo the 2-3 10mm nuts holding the ABS bracket to the strut tower. Unbolt the master from the booster and let the hoses flex, then work with the abs/master loose and you can get in there. I said it sucks, so don't expect any roses for happiness until it's all back in place.
  3. #3 Re: Air Conditioner issue: Evaporator Tube Assembly needs to be replaced.
    Kennesaw, GA
    Thanks. I found a thread for replacing the orifice tube and saw the pictures you posted for that. For my specific situation, I also had to remove the throttle body. I did the L36 to L26 mod back at the first of the year and the TB was in the way. I worked the tube as far forward as I could and was able to finally get the d**n thing apart and out. Putting the new one in was much worse. Not a job I'd ever want to do again. Sorry, but I didn't take pictures this time.
  4. #4 Re: Air Conditioner issue: Evaporator Tube Assembly needs to be replaced.
    Only reason I have those pics was to prove out how crappy it was. Glad to hear you had success. Meanwhile..I hope you had the beer chilled, knowing it was gonna suck.
  1. A/C evaporator 01 GTP, how do we get it out???
    By Bunnystac in forum General Tech Discussion
    Last Post: 06-22-2012, 03:57 AM
  2. Evaporator Control Valve
    By 00Kevin in forum General Tech Discussion
    Last Post: 05-31-2010, 10:34 PM
  3. Evaporator Drain Location?
    By 05pontiacgprix in forum General Tech Discussion
    Last Post: 01-31-2010, 03:14 PM
  4. Looking for evaporator tubing ends at TB
    By nlinesk8s in forum General Tech Discussion
    Last Post: 01-11-2009, 05:43 AM
