Thread: timing advance
Results 1 to 9 of 9
  1. #1 timing advance
    Jul 2013
    adrian, mi
    what are good timing advance numbers to see with 3.4 setup. im seeing 13.5* wot and 27* cruising on the highway. 98 gtp
  2. #2 Re: timing advance
    Sounds fine.
    27 seems low on the freeway, but you must be doing well over 75+ mph, timing falls as speeds increase, aswell as gas mileage. Around 65-70 you'll see near 30ish.
  3. #3 Re: timing advance
    Well, considering 16* is stock and anything less sucks...
    I'd say don't worry about the cruise timing right now as its fine, worry about the WOT tune.
    What's the AFR? Any KR? What mods?
    Jul 2013
    adrian, mi
    bout 85
    not seeing kr but the wot timing is making me think the kr gauge isnt working
    i will check the afr over lunch and post back here
  5. #5 Re: timing advance
    One post will get it done skipper; three aren't needed.
    KR gauge? You have an Aeroforce then?
  6. #6 Re: timing advance
    Jul 2013
    adrian, mi
    al 104's, 180* tstat, 3" dp, 3.4 mps, open cone intake, ported front manifold.
  7. #7 Re: timing advance
    Jul 2013
    adrian, mi
    my bad. torque app with blue tooth obd2
  8. #8 Re: timing advance
    If it doesn't knock then get someone to tune it...
    lean it out and up the timing until it does.
    You want at least 16* and I don't care for anything in the 10's AFR wise.
  9. #9 Re: timing advance
    Jul 2013
    adrian, mi
    alright thanks man
  1. Timing advance and afrs
    By blackflag in forum General Tech Discussion
    Last Post: 05-25-2012, 04:55 AM
  2. Kr via timing advance?
    By 99PontiacGTP in forum General Tech Discussion
    Last Post: 02-06-2012, 12:33 PM
  3. Stock timing advance for 98 GTP???
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2011, 09:55 PM
  4. Whats normal timing advance at idle?
    By goldgp in forum PCM Tuning
    Last Post: 03-29-2010, 10:18 PM
  5. what to expect with timing advance
    By TehGTP in forum PCM Tuning
    Last Post: 12-07-2008, 08:05 PM
