So my drivers side lower ball joint went so I replaced it and a few days later there was grease all over my rim it was coming out of the bottom of the ball joint ( not around the rubber at all) so I took it off sent it back they sent me a new one I put it in and what do you know does the same thing leaks out the bottom in the same exact area, can anyone help? Should I go somewhere else for a ball joint? Is this common? Thanks in advance
