Thread: Toggle Position Sensor put my car into permanent race mode
Results 1 to 10 of 10
  1. #1 Toggle Position Sensor put my car into permanent race mode
    Apr 2012
    Providence, RI
    A bit of a long story so please bear with me. Two days ago the car gets sluggish, can't pass, can't go up hills, hesitation in the pedal.... So I'm thinking fuel delivery problem, maybe the CC. I turn the ignition on and pop the hood. The idle air control valve is madly clicking away. Click, click click......
    So I deem that can't be good and I replace the IACV. The car is a bit better, but still its like driving through mud, and I still have the question of fuel delivery. Since it was time I put in a new fuel filter and test the fuel pressure. 45 psi at ignition, dropping to 39 or so psi when you turn on the motor. So the fuel delivery is just fine.
    Next, I get an OBD scan down at the local auto parts store and the Toggle Position Sensor comes up. Like an idiot I don't get the code, but I get the sensor. I replace the TPS and now the car is in permanent acceleration mode. Throttle wide open all of the time. Makes braking rather interesting and its super quick off the line, but not the ideal case for family driving. My multimeter says the car is sending 5V to the TPS on the grey line just like it should with a small mV signal on the blue and black wires.
    Does anyone know what is going on with this? Would a misreading of the pressure in the manifold cause the toggle butterfly to stay open forever? Can the butterfly get stuck? If other folks have other ideas I'm all ears.
  2. #2 Re: Toggle Position Sensor put my car into permanent race mode
    GT Level Member Deviq's Avatar
    SE WI
    Did you just slap the tps straight on? You have to watch where the little L bracket clip (term?) is and to make sure it's in front of its mating part. Slide the tps on at a 2 or 3 o'clock position and then turn it to align the holes.
    I don't know all the terms for the pieces inside so maybe someone can clarify.
  3. #3 Re: Toggle Position Sensor put my car into permanent race mode
    You mean throttle position sensor, not toggle.
    Do what he said, or get a new one.
  4. #4 Re: Toggle Position Sensor put my car into permanent race mode
    The Boss Iceman6669's Avatar
    Jun 2011
    I had a VERY similar issue after my build. Reinstalled the TPS and when driving every time I left off the gas car would stall... I reinstalled correctly and fixed the issue.
    2011 F-150 Yote powered
  5. #5 Re: Toggle Position Sensor put my car into permanent race mode
    Apr 2012
    Providence, RI
    Well the high revving came from the idle air control valve, for some reason it didn't fit properly or the computer didn't learn the first time, but after I loosened and tightened some of the bolts on the throttle body and re-seated the IACV the high revving went away. This morning I installed the TPS again, I do believe I aligned it correctly as mentioned but I am getting a PO122 error, low voltage to the TPS. The car idles at 800 rpm, just a low rumble, it has low, easy acceleration but no 'po' like it used to have. I am going to double check the seating of the TPS as soon as the engine cools.
  6. #6 Re: Toggle Position Sensor put my car into permanent race mode
    Feb 2009
    flintnasty MI
    There is a TPS learn procedure...
    pedal down key on, key off, pedal up key on, key off repeat 4 times.
  7. #7 Re: Toggle Position Sensor put my car into permanent race mode
    Apr 2012
    Providence, RI
    I did something similar, with the car in ignition mode I pressed the gas pedal fully 5 times and then shut the engine off. I had misaligned the TPS fitting the first time, I had it dialed in, but not flush with the throttle body. Second fitting solved that problem. Car still has power problems though. P0300 was the latest error. Sparks and coils were just redone, fuel line pressure to before the injectors seemed to be fine.... so I guess it is the oxygen sensors, or CC..... I guess I will find out tomorrow at the shop.
  8. #8 Re: Toggle Position Sensor put my car into permanent race mode
    P0300 still means misfires.
    So either you may have cracked one of the plugs upon install or you put in some crappy plugs like e3's or platinum plugs.
  9. #9 Re: Toggle Position Sensor put my car into permanent race mode
    Apr 2012
    Providence, RI
    The P0300 wasn't spark plug, or coil related...and it shouldn't be cause I just had new plugs, new coils, fuel injector wash and few other maintenance things done. And the P0300 code is confounded by two problems existing as once. My check engine light never came on, and my service engine soon light would come and go. The IAC went madly clicking away because one of the lines on its circuit was corroded. At the same time, or very similar time the CC plugged. I suspected the green wire going to to IAC as it had wildly varying voltage, but I couldn't find values for the voltages.
  10. #10 Re: Toggle Position Sensor put my car into permanent race mode
    Let's keep in mind...new Bosch or platinum plugs can cause misfires almost as soon as they are put in. Same goes for a plug that was installed incorrectly and cracked or one that was dropped and cracked.
  1. Cam position sensor
    By Abrehm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2012, 09:53 AM
  2. Cam Position Sensor
    By SilvrGrandPrixGT in forum General Tech Discussion
    Last Post: 08-23-2011, 04:21 AM
  3. throttle position sensor
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2010, 11:16 AM
  4. cam position sensor
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 02:16 PM
  5. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
