Thread: ...
Results 1 to 12 of 12
  1. #1 ...
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  2. #2 Re: What are ALL the conditions that will turn the fans on?
    the fan will be on if the ac is on and if the temp gets to a certain temp or if the ect is unplugged.
  3. #3 Re: What are ALL the conditions that will turn the fans on?
    You sure like to ask alot of question based on temps, seems that you already know how and when the temps come on but still ask more questions.....
    Like Dsmut said, if the AC is on the the fan comes on. If the temps reaches 214 with no AC, the low fan turns on and at 228 the high speed. If you unplug the ECT sensor, the fans will come on.
    Nothing else controls fans, nothing. No air, no rpms, no engine speed, no nothing.
    The temps you are seeing are not super abnormal for a hot summer day with the car NOT moving, its going to heat soak in a matter of minutes and raise the temps.
    I still think half your problem is your radiator, to me its not able to do its job properly. You've said in the past its been replaced and cleaned, but in that roughly 70-80K miles who knows whats its been through. A fellow member recently was having temp problems even after replacing thermostats and doing coolant flushes, turns out his radiator was the cause for the rising temps because the insides of the radiator were bad.
  4. #4 Re: ...
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Once at temp, shut off your car and feel the front of the radiator. If some spots seem cooler then others, you have a blockage..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  5. #5 Re: ...
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    Go to orileys and get a 1 3/8" radiator for a monte carlo 130$ direct fit with a little macgyver-ing and it wont ever go above 190*. There is a how to on this site.
  6. #6 Re: ...
    Omaha, NE
  7. #7 Re: ...
    Feb 2013
    Missoula, MT
  8. #8 Re: ...
    I live here. DirtDog's Avatar
    Jun 2012
  9. #9 Re: ...
    Omaha, NE
    DotDotDot
  10. #10 Re: ...
    Feb 2013
    37.295091, -121.930053
    your a dot im a dot we're all dots
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  11. #11 Re: ...
    Nov 2009
    Tennessee
    .........commmmmmmmmmmmmmmm
  12. #12 Re: ...
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    s
    (please ignore this bit in parenthesis as it is filler fro the stupid minimum character count)
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  1. turn fans down for me.
    By leigh in forum West
    Last Post: 05-28-2012, 08:53 PM
  2. turn fans down for me.
    Last Post: 05-28-2012, 08:52 PM
  3. Cooling Fans wont turn on until at like 235F
    By jhnnyboz in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-20-2011, 09:34 AM
  4. fans dont turn off
    By backinblackgtp in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 02:33 PM
  5. 92 GP Electric fans won't turn on... HELP Please
    By smurfboy in forum General Tech Discussion
    Last Post: 09-25-2008, 12:01 PM
