Thread: Will an aftermarket tuner such as a BullyDog allow me to delete code P420 from PCM?
Results 1 to 9 of 9
  1. #1 Will an aftermarket tuner such as a BullyDog allow me to delete code P420 from PCM?
    SE Level Member grandprixgtcv3's Avatar
    phoenix, az
    Bully Dog 40402 Bully Dog WatchDog Economy Engine & Vehicle Monitor Will this allow me to remove P420 from the PCM forever or will I have to buy an aftermarket PCM to accomplish this?
    grandprixgtcv3
  2. #2 Re: Will an aftermarket tuner such as a BullyDog allow me to delete code P420 from PC
    Feb 2013
    37.295091, -121.930053
    dude just clear the code go to autozone or some other place that has a code reader
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Will an aftermarket tuner such as a BullyDog allow me to delete code P420 from PC
    Quote Originally Posted by grandprixgtcv3 View Post
    no, and you dont want to delete it permanently either. The code comes up for a reason...
  4. #4 Re: Will an aftermarket tuner such as a BullyDog allow me to delete code P420 from PC
    May 2008
    Schuyler, NE
    Lol.^^
    The bullydog won't delete it. You will need a tune for that.
  5. #5 Re: Will an aftermarket tuner such as a BullyDog allow me to delete code P420 from PC
    phoenix, az
    I want it deleted due to a high flow cat. Do you recommend any tune or PCM? I checked 3800 performance and ZZP both don't say that it will remove the code. Probably my best bet is to call them but I wanted to see if anyone has done the same already!
    grandprixgtcv3
  6. #6 Re: Will an aftermarket tuner such as a BullyDog allow me to delete code P420 from PC
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    just get an o2 emulator from ZZP it's like 30 bucks and spoofs it to make it think there is a cat.
  7. #7 Re: Will an aftermarket tuner such as a BullyDog allow me to delete code P420 from PC
    Just google spark plug non-fouler trick. ~$5 fix.
  8. #8 Re: Will an aftermarket tuner such as a BullyDog allow me to delete code P420 from PC
    Quote Originally Posted by addzradd View Post
    He has a 05. According to ZZP won't work
    04 Comp G.
  9. #9 Re: Will an aftermarket tuner such as a BullyDog allow me to delete code P420 from PC
    Quote Originally Posted by slick2500 View Post
    Bingo. Exactly what I did until I send my PCM back to will for a retune.
    04 Comp G.
  1. P420 code
    By Bluemagic in forum General Tech Discussion
    Last Post: 09-18-2018, 11:33 PM
  2. EGR Code delete using torque pro
    By Beelzeboul in forum PCM Tuning
    Last Post: 08-18-2012, 04:47 PM
  3. Replies: 1
    Last Post: 06-13-2012, 05:46 PM
  4. Delete EVAP code
    By Deathsports in forum PCM Tuning
    Last Post: 11-09-2010, 04:17 PM
  5. If i delete the rear 02sensor code(p0420)
    By kinglou10 in forum PCM Tuning
    Last Post: 07-02-2009, 05:22 PM
