I don't know anything about engine synching but what happened during the burnout? Sounded like one of the engines unspooled about a 1/2 second after the other.
Tried timing retard, timing advance. Large and small amounts on both sides.
DIfferent fueling settings (RICH, LEAN IN BETWEEN)
The best setting was stock timing map down low with 12.5 a/f ratio.
But remember I stall at 1600rpm and under 8 psi of boost 2700rpm within 3.5 seconds, that is very low and it acts different than the other motor that stall easily to 3600rpm + under boost in 2 seconds
Raised the boost. Manage to get half decent auto shifts on the 4t80e trans.
Big power now... can't wait for this weekend. This video shows a little of what it is like inside the cabin.
DAMN!!
Make sure you record the track runs. 1/4 mile would be nice to see
How'd she do?
Nevermind, saw the video. Nice work!
For those following the progress on this thread... it ran 9 second 1/4 miles three times in a row.
First two runs at 60% throttle in the back. Last run 9.72 @ 139 mph full throttle on both.
Went for a higher boost run on the rear engine and at 20 psi on the launch we hurt the 4t80e trans.
It would have made a very quick pass as I left with more boost off the line plus more boost all the way to the top as well.
Very hot and humid day at the track.
Sent from my iPhone
WOW!!!! Just WOW!!!
I may have missed it somewhere, i'm curious as to how much this project has ran you, including the cost of the car. If you don't mind. If you'd rather not say that's fine.
I wish...
It's hard to say how much is in that car. Most of it is time.
I have about 10K in parts total with the car. Most of that money is for the turbo kits that we built (the turbochargers are the most expensive part of the project)
Then the rest is labor. I probably paid over 6K in labor total. My cost for my employees at the shop. And I'm not counting my own time, so 10K total if I pay myself.
If we were to build a replica, it would talk half the time or less. So I would charge 10K to build one but you supply the parts to build and the car.
Total for a customer that car would cost around 20K. 25K for the final details and a 100% turn key car (better suspension than what I have, complete wiring job etc..)
