Thread: a/c compressor labor
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: a/c compressor labor
    GT Level Member Shiftingshaddow's Avatar
    KC
    Quote Originally Posted by camopaint0707 View Post
    It was a ***** with everything in the way.
    really? could do everything underneath. there's nothing there in the way. put it on ramps. one of the easiest things I've done to one of these.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  2. #22 Re: a/c compressor labor
    Quote Originally Posted by Shiftingshaddow View Post
    He's a complainer.. speaking of..I might change his name. Complainer0707 Yup..off to do that.
  3. #23 Re: a/c compressor labor
    Pennsylvania, USA
    Bill, you got over 200k on a single compressor? Jeeze, mine is making a ridiculous "hooting" sound and my car doesn't even have 100k on it yet :P
    I can decide on the orifice either, I just have a leak and that strange noise, so if it isn't leaking back near the orifice, I may just do the evap and compressor.
    Morad parts kicks ass for these jobs, I just can't spend as much as places want for a brand new one.
  4. #24 Re: a/c compressor labor
    Rockauto had a Delphi with my name on it for $165 plus shipping. Didn't say reman either. I'm unsure if it is or not.. for $165 it's likely reman.
    Pretty sure my fuel filter has 220K on it as well. Same as the fuel pump (which I run pretty dry all the time)
  5. #25 Re: a/c compressor labor
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I was looking at that also Bill, did you see the compressor kit they had for $198 or so ?
    1997 Red GTP 182000 miles stock
  6. #26 Re: a/c compressor labor
    No... I missed that.
  7. #27 Re: a/c compressor labor
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    I got the same delphi compressor from rockauto. The replacment was a breeze. sitting underneath the car i was able to get the 2 bolts in back along with the nut holding on the lines, and the 3 in front where beyond easy with the passenger tire removed. She came out with ease right through the wheel well. Accumulator was even easier. I didnt do the orifice tube though. Even with the master cylinder and ABS out of the way, it still looks like the power booster will have to come out. F that.
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  8. #28 Re: a/c compressor labor
    You can sneak in there... it's always a pain. Pretty sure even though the FSM didn't say it..there's a special Jtool for undoing those things
  1. 4 way flasher switch broken, $370 for part + labor...
    By TomOfTarsus in forum General Tech Discussion
    Last Post: 11-06-2012, 07:54 AM
  2. Compressor
    By InfidelRebel in forum General Tech Discussion
    Last Post: 08-13-2009, 01:41 AM
  3. ac compressor help
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2009, 02:28 PM
  4. AC Compressor
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2009, 02:56 PM
  5. Happy Labor day
    By TDCRacing in forum Off Topic Discussion
    Last Post: 09-01-2008, 09:47 PM
