Thread: Electrical
Results 1 to 16 of 16
  1. #1 Electrical
    ohio
    Ok I dont know whats going on my brake lights wont work but the middle one does. When I have my headlights on my brake lights are illuminated but when I hit the brakes they dont go bighter but the middle one does. Also my blinkers and hazards dont work but if I push the button down for the hazards and hold it only the front right blinker will blink. I was messing around by the fuse box in the glovebox and got a spark before all this happened. So could it just be the fuses or what else could it be.
    I have a 1997 grand prix se.
  2. #2 Re: Electrical
    Feb 2008
    Most likely you have burned out bulbs. They are dual element, that is why you have tails but no brake lights.
    Tail lights on 1 element.
    Brake lights and turn signals on the other element.
  3. #3 Re: Electrical
    ohio
    Wouldent that be kind of weird for my front and rear blinkers to just burn out and none work?
  4. #4 Re: Electrical
    Feb 2008
    Quote Originally Posted by 97gp97 View Post
    Not if you do that^^^
    Take them out and look at them, most of the time it is not difficult to see if they are burned out.
  5. #5 Re: Electrical
    ohio
    Maybe ill go replace one of the tails real quick.
  6. #6 Re: Electrical
    ohio
    Well the bulb looked fine but I replaced it anyway but it didnt help any.
  7. #7 Re: Electrical
    ohio
    anyone else?
  8. #8 Re: Electrical
    Feb 2008
    hmmm, did you check your fuses?
  9. #9 Re: Electrical
    ohio
    Well I only checked my turn signal fuse and it was fine, tomorrow I will probably go through all of them.
  10. #10 Re: Electrical
    Feb 2008
    Yeah, I would do that. It's hard to say what the deal is, but it sounds like the spark when you were "messing around in the fuse box" did something. Good luck and let us know what the deal is.
  11. #11 Re: Electrical
    ohio
    Yeah I was pulling my speaker wire through the rubber sleeve from the door and I grabbed it with some pliers through the glovebox and thats when I got the spark.
  12. #12 Re: Electrical
    Feb 2008
    Hmm, you might have a broken or shorted wire then. This no longer sounds easy. I'll bet you either pulled the wire that goes to the turn signals from its contact or it shorted out against the body somewhere. Your gunna have to get down and dirty and figure out which wire it is.
  13. #13 Re: Electrical
    ohio
    Cool now I get to take my dash off tomorrow.
  14. #14 Re: Electrical
    ohio
    Any write ups on how to take the dash off anywhere?
  15. #15 Re: Electrical
    ohio
    And I just found out when I got in my car this morning my radio doesnt work either. I've checked my brake,turn,radio, and a couple other fuses and there all good. So anybody have any ideas?
  16. #16 Re: Electrical
    ohio
    Since im replacing my speakers is there a chance this could have been caused by the old speaker wire touching the metal door and shorting out. Is that a possiblility?
  1. Electrical switches?
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 07-14-2008, 11:33 PM
  2. electrical? I am frustrated!
    By smitch in forum General Tech Discussion
    Last Post: 06-23-2008, 11:02 AM
  3. Electrical (HELP)
    By tooez in forum General Tech Discussion
    Last Post: 05-24-2008, 07:28 PM
  4. The Electrical Work Is Done!!
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2008, 03:43 PM
  5. Lots of electrical issues
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-31-2008, 11:14 PM
