Thread: 2004 gtp cooling fan problem - help
Results 1 to 5 of 5
  1. #1 2004 gtp cooling fan problem - help
    Sep 2012
    Chicago
    My 04 GTP cooling fans only work when I turn on the A/C. They will not turn on if I have the A/C off and the engine will run really hot if I am idling. It will run cooler if I am driving because air is passing through the radiator. If anyone can help, please chime in on what to look for or look at.
    Thanks for your help!
  2. #2 Re: 2004 gtp cooling fan problem - help
    What temp is the dash reading when it runs hot?
    Does the pcm temp correspond to the dash temp?
  3. #3 Re: 2004 gtp cooling fan problem - help
    Sep 2012
    Chicago
    I dont know what the actual temp is, however, if I just leave the car running parked, the temperature gauge will go past the 3/4 mark, just a few notches from the redline area. If I turn on the A/C, leaving the car parked and idling, the fans will then turn on and the gauge will drop to the 1/2 mark or a notch or 2 below. I dont currently have a way to check the PCM, but I am willing to buy something if needed to check it out. I have owned the car since new and it used to always run at or below the 1/2 mark just about all the time. No matter how hot the temperature gets without the A/C on, the fans will never turn on. I hope this info helps.
  4. #4 Re: 2004 gtp cooling fan problem - help
    SE Level Member Peirce1970's Avatar
    Myrtle beach, S.C.
    I've had the same problem with my 04 ever since I bought it. Whoever had it before me put a jumper wire from a fuse to the fan relay so the fans run all the time on low speed. My mechanic looked at it an kinda thinks its a short in the fuse box. I have a new temp sensor just haven't installed it. Other than that it could be a problem in the pcm
  5. #5 Re: 2004 gtp cooling fan problem - help
    Pennsylvania
    I fixed an 04 with the same issue by cleaning the connectors in the fuse box... they get all burnt and fail.
  1. # 1 cooling fan problem on a 98 GTP - I need your help please!
    By Penguinsonfire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2012, 01:20 PM
  2. 2004 3.8 Cooling system problem
    By MOOSEDAWG in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2012, 09:46 PM
  3. Cooling fan problem
    By dipset1413 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2012, 10:12 PM
  4. 04 gtp cooling problem
    By dipset1413 in forum General Tech Discussion
    Last Post: 11-07-2011, 09:58 AM
  5. Cooling Problem
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 06-17-2009, 10:53 AM
