Thread: Exhaust - Save money or delete res?
Results 1 to 7 of 7
  1. #1 Exhaust - Save money or delete res?
    GT Level Member Pokealong1227's Avatar
    Oct 2012
    Oak Grove, MO
    Okay so against some peoples advice I got Super 40s from flowmaster and put them on my stock exhaust. I'm not sure if I got lucky or what but it sounds perfectly fine to me. Zero rasp, not loud or obnoxious, no drone on the highway, and with my new intake it sounds even better. But now I need a new downpipe. I've heard the u-bend is the most restrictive part of these cars so I plan on getting a 2.5" 304SS downpipe with cat from zzp. My question is, should I get a resonator delete too, or just leave the stock resonator and stock piping? Money isn't really an issue because I've been getting a ton of hours lately(about 50% more than usual). I've heard it's cheaper and better to just leave the resonator in to eliminate drone and rasp since it isn't very restricting and just get a new downpipe. I've never heard a car without a resonator other than a little 4 cylinder that had rasp already. What are your opinions?
  2. #2 Re: Exhaust - Save money or delete res?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    If you delete the resonator you'll have a rasp monster and a horrible sounding car.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  3. #3 Re: Exhaust - Save money or delete res?
    Pennsylvania
    If restriction's your concern, why not just get a 3" dp instead of a 2.5" with resonator delete?
    IIRC, running without a cat, resonator, and mufflers is only a ~5% hp increase... hardly worthwhile. Taking out the resonator might give you a half a horse if anything at all.
  4. #4 Re: Exhaust - Save money or delete res?
    May 2012
    Albuquerque, NM
    I installed headers, 3" catless DP, dumped stock res, install small (12"-18"x 3"-4" dia) res from local muffler shop that included the tubing to drop from 3" to stock exhaust and it hardly adds any drone/rasp but sounds great under WOT. Experiment a little.
  5. #5 Re: Exhaust - Save money or delete res?
    Apr 2012
    Goderich, Ontario
    I've got the same setup your planning on, ZZP dp and Flowmaster 40's. I made the mistake of taking my res off when installing the dp. I put the res back on the next day. Also, the dp will make your car a little louder then it is with just the muffs.
    -Paul Walker
  6. #6 Re: Exhaust - Save money or delete res?
    Omaha, NE
    Put a glass pack in its place.
  7. #7 Re: Exhaust - Save money or delete res?
    Oct 2012
    Oak Grove, MO
    Quote Originally Posted by smoke14 View Post
    Good answer. And as for the 3" dp question from a previous poster, I don't see the little downpipe being 0.5" bigger creating a huge difference. I appreciate all the feedback, I will definitely leave the resonator on. My car already sounds pretty great and fairly loud(loud enough for my liking about 3k rpm). I think I'll be happy with just the new dp and save a good chunk of change too.
  1. Keep or delete res. for exhaust
    By Jbruce308 in forum General Grand Prix Discussion
    Last Post: 04-15-2012, 12:43 AM
  2. DP/U-Bend Delete/Exhaust Q??
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 01-11-2011, 12:49 AM
  3. Do you need spare key? Save yourself some money
    By jb2hot927 in forum Shops and Community Heroes
    Last Post: 03-06-2010, 07:13 PM
  4. Stock exhaust, go straight to 3" stainless or do U bend delete first?
    By telkel2399 in forum General Tech Discussion
    Last Post: 12-07-2009, 09:12 AM
  5. Muffler delete? looking for cheap exhaust sound increase
    By Freebeer187 in forum General Tech Discussion
    Last Post: 09-30-2008, 09:36 PM
