Thread: Broken GM Engine Mount Strut Bracket
Results 1 to 9 of 9
  1. #1 Broken GM Engine Mount Strut Bracket
    Sep 2012
    Dealership
    I noticed my engine was rocking a bit to much when I would go from reverse to drive. So I checked under the hood.
    Its on the passenger side in the front of the engine, connected to the dog bone. I guess it is aluminum , it is silver.
    I know how to replace the part, I'm just wondering what would cause it to break. I don't want to replace it and it breaks again...
    New GM Engine Mount Strut Bracket Grand Prix Impala Regal Lacrosse..Here's a link. It broke about 1/4 inch above the mounting whole on the right side, where it bolts to the upper intake.
  2. #2 Re: Broken GM Engine Mount Strut Bracket
    Dec 2012
    Where 4T65E's were born
    Over tightening will break it.
    Sold.
  3. #3 Re: Broken GM Engine Mount Strut Bracket
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    What year car do you have? High mileage? I ask because I'm wondering if your rubber mounts *round ones in the dog bones, square ones in the brackets above your radiator* are bad. If you have a lot of play in those rubber mounts it could have lent a hand on breaking it. My $.02 lol
    And before you spend $76 for that thing, post an add in the wanted parts section and see if you can get one.. I'm sure people have several laying around.. Heck I had three of them, but went looking for them the last time this happened to someone a couple months ago, but couldn't find them..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  4. #4 Re: Broken GM Engine Mount Strut Bracket
    Sep 2012
    Dealership
    Yeah Its a 2001 prix non supercharged 150,000 miles.... I guess I should replace the rubber mounts in the dog bone brackets..Ill check around locally to see if I can find it cheaper first. Thanks
  5. #5 Re: Broken GM Engine Mount Strut Bracket
    May 2008
    Winnipeg, MB
    pick n pull yard is a great place to find those, thats where I got mine for like $5
    I don't have it installed, (long story) no problems so far
    2007 Pontiac Grand Prix
  6. #6 Re: Broken GM Engine Mount Strut Bracket
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Yeah go to a pull a part type yard, it isn't bad to get to just have to pull off the ICM, at least if you get one off once yourself you are ready to go on yours.
  7. #7 Re: Broken GM Engine Mount Strut Bracket
    Sep 2012
    Dealership
    Thanks guys.
  8. #8 Re: Broken GM Engine Mount Strut Bracket
    They commonly break exactly where yours did. It's pretty normal actually. hell... I pulled a broken one off an engine just last night.
    Personally since there's some wiggle room, I think that the one side gets more pressure.
  9. #9 Re: Broken GM Engine Mount Strut Bracket
    Jun 2012
    South west Michigan
    Mind finely broke on the pass. side now here comes the good question....just exactly how do you get that one hex female bolt out? its right up next to an injector and its angle is toward the intake manifold.
  1. Broken engine bracket
    By tod1d in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-14-2013, 08:48 AM
  2. Replies: 4
    Last Post: 02-09-2013, 11:36 PM
  3. L67 coil mount/engine mount bracket (passenger side) on an L36
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2012, 10:08 AM
  4. Upper Engine Torque Strut Mount Bolt Question
    By janaya3 in forum General Grand Prix Discussion
    Last Post: 01-30-2012, 11:46 AM
  5. Oil pan gasket - removing 15 mm bolt at top/rear of front engine mount bracket - 2004
    By jkk9 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2011, 06:40 PM
