Thread: Installed my new sway bar
Results 1 to 9 of 9
  1. #1 Installed my new sway bar
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    Just as the title states, I installed the bar today and it was the first time I have put one in. It was not that bad of a job and took me about an hour. I didnt have to drop the tierod(s) or the craddle. I slid it out the passenger side and put the new one in the through the drivers side. I lubed the bar up and then hit it lightly with a hammer where it was rubbing the frame. It slid right through with no prob....again without disconnecting nothing. I bought the Doorman bar. It was THREE times heavier and def made waaay better than the junk OEM one. Doorman was thicker too. I noticed that some people stated that they installed it upside down by accident. On the Doorman bar I bought, it was stamped in white paint "Bottom and drivers side", indicating where and how it should be placed. It was self explainatory. Easy job, with marked improvement. Next I will be doing the lower control arms. RA has them for less than $40.00 smacks a piece. Way cheaper than Advance, which btw is where I bought the bar today. It was $99.00 bucks, but I entered the TRT30 code and got 30% off!!
  2. #2 Re: Installed my new sway bar
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    The thing is if you have a larger downpipe or headers you WANT to install it upside down, it will keep it from hitting anything.
  3. #3 Re: Installed my new sway bar
    Dec 2010
    Cincinnati, Ohio
    I have a 3" downpipe and its nowhere near it. I guess I just lucked out.
  4. #4 Re: Installed my new sway bar
    Feb 2010
    TN
    Dam never though of doing it that way and since I will be putting one in soon thanks in advance
  5. #5 Re: Installed my new sway bar
    if you used the dorman bushing, well in a years time or less they will be shot, they suck, mine are blown out already. time to get some polly bushings.
  6. #6 Re: Installed my new sway bar
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    X2
  7. #7 Re: Installed my new sway bar
    When you install a bar, I always install it with the center point facing down. That way future mods are ready to go. BTW if you used retailmenot.com you could have gotten $40 off your order of $100.
  8. #8 Re: Installed my new sway bar
    The Boss Iceman6669's Avatar
    Jun 2011
    Now see when I installed my Doorman sway I put it in up side down at first( on accident) and it would NOT work. My tie rods would hit it once I turned the wheel more then like 15*.
    2011 F-150 Yote powered
  9. #9 Re: Installed my new sway bar
    Dec 2010
    Cincinnati, Ohio
    Im definitely going to invest in poly bushings. I wish I would have found the retail me not coupon. just wondering kind of a different topic but on the same topic of suspension work, has anybody used Bilstein shocks?
  1. Sway Bar
    By Iceman6669 in forum General Tech Discussion
    Last Post: 03-22-2015, 03:48 AM
  2. Odd sway
    By buickman104 in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2011, 09:29 PM
  3. DP and sway bar
    By gtpinsc in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2010, 08:51 AM
  4. GMPP Sway Bars installed
    By dhall9 in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 02:04 PM
