Thread: Cleaning engine bay
Results 1 to 20 of 20
  1. #1 Cleaning engine bay
    May 2013
    United States
    What is a good way too clean down my engine bay? Its soo dirty and what should i deffinatly cover up .
  2. #2 Re: Cleaning engine bay
    antioch ill
    coil packs and air filter. get a spray bottle fill it with simple green have fun
  3. #3 Re: Cleaning engine bay
    May 2013
    United States
    Quote Originally Posted by Matt Palm View Post
    How about the altenater and battery do i gotta worry about the spark plugs?
  4. #4 Re: Cleaning engine bay
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    All I do is cover the coil pack, air filter, and alternator with a plastic bag. Then take simple green and spray it everywhere. Let is sit for like a minute and then take a brush of some sort and just quickly brush over everything to agitate all the dirt and then spray down the engine with water. I wouldn't suggest using a pressure washer but I have heard of people doing that before. Also I wait for everything to completely dry before starting the car
  5. #5 Re: Cleaning engine bay
    Pfft covering anything, guess what happens when it rains or you go through a deep puddle at a good speed, oh right everything gets covered in water.
    Soap it down, scrub what you want and spray away. Either wait for it to dry or just start it up and go for a drive.
  6. #6 Re: Cleaning engine bay
    Feb 2013
    37.295091, -121.930053
    the engine will heat up the water so it will boil off
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  7. #7 Re: Cleaning engine bay
    Wichita
    Psssshh, unplug the battery. Soak everything with a spray can of degreaser, let set for a while, then wash with a hose. Let dry for a few hours.
  8. #8 Re: Cleaning engine bay
    I live here. DirtDog's Avatar
    Jun 2012
    Heck I drive my car 1 minute to car wash. Cover my air filter, then just put some orange stuff on it use a tooth brush in tight spots where dirt gets, theyln spray from a couple feet away with the car wash. I don't cover anything else
  9. #9 Re: Cleaning engine bay
    I will say this, if you have an aftermarket intake, don't spray that directly because there is no air box to cover it, but that should be common knowledge.
  10. #10 Re: Cleaning engine bay
    Feb 2013
    lol i use a pressure washer on the bottom and watch out for the frezze plugs but the block is what im after if i cant get the back of the block i will pull the engine out just to clean it. A little nuts but its worth it. It gives me the chance to also clean the tranny too. its nice seening all the clean parts under the hood.
  11. #11 Re: Cleaning engine bay
    Jun 2012
    ^^^^^damn son that's way to much work lol
  12. #12 Re: Cleaning engine bay
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    Purple Power Degreaser works great too.
  13. #13 Re: Cleaning engine bay
    Jul 2012
    Grand rapids
    *2 on purple power works great
  14. #14 Re: Cleaning engine bay
    Jan 2013
    Sioux Falls, SD
    I read from another thread on the forum is to use tire dressing on plastic parts. I did it to mine and its all clean and shiny
  15. #15 Re: Cleaning engine bay
    Quote Originally Posted by trojanone1 View Post
    give it 2 weeks, then go look at it again, it will look like crap, i did that one time, looks good, but every last speck of dirt sticks to it fast, looks worse then a dirty engine in a month.
    i learned my lesson with tire shine on the engine bay, wont happen twice.
  16. #16 Re: Cleaning engine bay
    Quote Originally Posted by mikey666 View Post
    if you have a stock air filter, you can hose the whole engine down, you need to cover nothing at all.
    if you have a cone filter, take it off, get a bag and a rubber band to cover the TB opening, thats all you need to cover.
  17. #17 Re: Cleaning engine bay
    Jan 2013
    Sioux Falls, SD
    still looks good a week later. We will see how it looks in another couple weeks.
  18. #18 Re: Cleaning engine bay
    you'll see.......
  19. #19 Re: Cleaning engine bay
    Pennsylvania
    A large, stiff paintbrush is probably more useful than a toothbrush.
    Tire shine is great and lasts months. The trick is wiping it completely dry after spraying it. The most useful spots for it are the heater hoses, since they look all dry and crusty after a degreasing.
    I've heard there is some merit to using Pledge cleaner to repel dust in the engine bay, but I've yet to try it.
  20. #20 Re: Cleaning engine bay
    Jan 2013
    Sioux Falls, SD
    you'll see.......
    ill let you know so u can say i told u so haha
  1. Engine Cleaning
    By Matthew Mericle in forum Introductions/Noob Questions
    Last Post: 12-03-2012, 04:12 PM
  2. cleaning the engine..
    By Mikey Bonefas in forum General Tech Discussion
    Last Post: 07-25-2012, 01:48 PM
  3. engine cleaning
    By busagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:53 PM
  4. Cleaning up the engine bay
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 07:22 PM
  5. Cleaning Engine Bay
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 08-19-2008, 01:42 AM
