I was driving home today and my low coolant light came on, I looked under the car to find coolant dripping at a high rate from where the water pump is, I felt around the pump and it was dry and the belts are clean, the bypass elbow is not broken and no leaks from the hoses that I can see, it has a new radiator. Like I said its comeing from the bottom of the engine somewhere but can pin point it cause its dripping from the oil pan but staying on the passenger side of the car. Am I missing something or is there a wheeping hole on the water pump I should check? are there any other things Im missing here? This is a 97 gp gt with 152,000 miles 3.8 nonturbo nonsupercharged. can anyone point me in a direction befor I decide to spend thousands takeuing it to the dealer?
