Thread: Can I get away with a Gates 65 7/8 belt ?
Results 1 to 5 of 5
  1. #1 Can I get away with a Gates 65 7/8 belt ?
    Feb 2013
    Ohio
    The closest Gates belt I could get locally is a 65 7/8 for my 3.5 pulley swap from ORielly, supposed to be 66 3/8. W body says 66 if I can get away with a 66 I don't think one more 8 th should matter. O says they can't order 66 or 66 3/8 ? Thanks
  2. #2 Re: Can I get away with a Gates 65 7/8 belt ?
    Feb 2009
    flintnasty MI
    I wouldnt... I like the 660 for the 3.4 stuff.
  3. #3 Re: Can I get away with a Gates 65 7/8 belt ?
    Feb 2013
    Ohio
    I have a 3.5
  4. #4 Re: Can I get away with a Gates 65 7/8 belt ?
    Nov 2012
    Madison
    Here are the numbers you need for those numbnuts at Oriellys, GS-K060658 or GS-K060660. I've used both on my 3.5. They have them, I checked
  5. #5 Re: Can I get away with a Gates 65 7/8 belt ?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    ^^^ x2 I'm running the GS-K060660. I'm using both 3.5 and 3.4 (watching for knock on either to pick which one I want to go with)
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  1. Free- Gates Belt Wear Gauge
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 12-16-2011, 01:25 AM
  2. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  3. Bill Gates and saving...
    Last Post: 08-15-2011, 06:08 PM
  4. can you run the car without the SC belt?
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2011, 10:09 AM
  5. Gates and Crowley at the White House - What Really Happened
    By Warhellride in forum Off Topic Discussion
    Last Post: 08-02-2009, 08:35 PM
