Thread: Dirt in my purge solenoid
Results 1 to 6 of 6
  1. #1 Dirt in my purge solenoid
    Apr 2013
    michigan
    I replaced my purge solenoid (the part up by the fuel cap) today an when i removed it i noticed dirt in the line that goes in to it. I reset my engine code an it didn't come back on yet. This dont seem good tho like the line is undone at the other end. Anyone got any advise?
  2. #2 Re: Dirt in my purge solenoid
    So you were in the rear wheel well, right? That's the dirtiest place that line should be located. Trace it around and see if it's cracked.
  3. #3 Re: Dirt in my purge solenoid
    Apr 2013
    michigan
    When I replaced it I did trace it as far as I could an didn't notice any cracks.
  4. #4 Re: Dirt in my purge solenoid
    Tough to tell you what's goingo n them. Only places it opens are to the fuel tank and evap valve plus the canister that you found.
  5. #5 Re: Dirt in my purge solenoid
    Apr 2013
    michigan
    Thanks for the advice. Its been two days now and the code has not came back so im hoping for the best! Thanks again.
  6. #6 Re: Dirt in my purge solenoid
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Could it be debris from the Canister itself?
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  1. EVAP purge/vent solenoid?
    By OriginalName in forum Introductions/Noob Questions
    Last Post: 04-30-2013, 06:37 PM
  2. will a purge solenoid make your car run like crap
    By dstrow73 in forum General Tech Discussion
    Last Post: 04-02-2011, 07:28 AM
  3. Purge Vent Valve/Solenoid testing
    By roundbox52 in forum General Tech Discussion
    Last Post: 09-29-2010, 07:36 PM
  4. purge valve solenoid/cylinder
    By CHAMPS97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 10:30 PM
