Thread: spark plug opinions
Results 1 to 17 of 17
  1. #1 spark plug opinions
    Apr 2013
    st louis
    have an 04 GTP, 3.4", cai, headers, tuned pcm, 160 therm
    currently running zzp wires and ngk tr55 plugs .059 gap with msd coil packs.
    thinking of swapping back oem coils and wires with tr55????
    any opinions? best setup? should i try running tr6s?
  2. #2 Re: spark plug opinions
    Personally I would not suggest running that cold of the Tstat. I'd bring that up to a 180F
    Which ZZP wires, the bad ones or the bad ones? Supposedly only the originals and latest batch are good.
    MSD coils, known to have spark issues at high rpm in as short as 3-6 months.
    TR55's, iridium or copper, you can get both.
    I'm thinking you are having some issues and that's why you are asking. The coils and wires are suspect. Running too cold is also an issue, as is running nearly a stock gap on a 3.4" pulley.
    Gap should be smaller
    Thermo should be 180F
    Coils should be stock
    Wires should be good (ZZP or whatever, but a good set)
  3. #3 Re: spark plug opinions
    Apr 2013
    st louis
    id have to reprogram the pcm to go back to 180. zzp wires bought on 10/11 10mm zzp. i already have 3 stock coils otw. smaller plug gap... like .057? and tr55 copper is in there now
  4. #4 Re: spark plug opinions
    Apr 2013
    st louis
    thinking coil packs are the biggest issue thats about the time frame i started getting a poopey misfire at topend
  5. #5 Re: spark plug opinions
    Most people recommend a gap of .050-.055.
  6. #6 Re: spark plug opinions
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I have never had those coil packs so I can't speak from experience, but everything I have read says stay away from them...
    That cool of a thermostat, in my opinion, is bad. If you are opening the thermostat to soon/to often, the coolant is not sitting in your engine long enough to absorb the majority of the heat. The sensor reads coolant temp, not engine temp. Coolant could be 160* but your motor could be a lot hotter. If this makes sense? Something to think about...
    I'm running standard copper Autolite's in my car, have for 4-5 years now on stock wires. I have to change them more often, but not had issues. Gapped at .050ish... I'll upgrade wires eventually, just like the lifetime warranty on the stock replacements..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  7. #7 Re: spark plug opinions
    Ok.. since you say there's an issue and the programming to overcome. I'd suggest taking this one step at a time.
    Change only the MSD's. See if the issue still exists.
    Change your gap, so there's no worry about blow out. See how that goes.
    Then wires
  8. #8 Re: spark plug opinions
    Apr 2013
    st louis
    im not a master tech nor a virgin or "noob" lmao. this is not intended to be condesending so please dont take it this way. the prix has +200k miles on it. been running 160* since 120k miles no issues. i do know what the sensor reads (db) i appreciate the advice on the running temp, however engine temp is not the root of my current discussion. just seeing what people either run, or suggest to run on that platform. probably going with tr55 copper gapped at .050-.055, stock coils. plug wires im up in the air on, not a big fan of the zzps seemed homemade when i got them. before anything going to get fuel injectors cleaned and combustion chamber cleaning.
    used to run this car down the track now shes just a fast grocery getter...
  9. #9 Re: spark plug opinions
    Apr 2013
    st louis
    yea its past remodding, if i could do it again i wouldve done it differently trust me. and thats the plan billboost. coil, gap, wires. thanks everyone
  10. #10 Re: spark plug opinions
    Pennsylvania
    an issue is running nearly a stock gap on a 3.4" pulley.
    I have yet to get an answer from anyone as to how this helps anything at all. I've yet to see anyone have an issue (and how would that issue manifest?) with stock gap on a 3.4" setup. But I see daily recommendations for smaller gap from people who have never experimented with gap. Any chance you can lay down some knowledge?
  11. #11 Re: spark plug opinions
    Apr 2011
    Vassar, Mi
    Quote Originally Posted by SlowNA06 View Post
    More boost from a smaller pulley will be more likely to blow out the spark and create a misfire. Tightening the gap will prevent this. I run AL104's at .050 and change them every other oil change.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  12. #12 Re: spark plug opinions
    Quote Originally Posted by Anthony Smith View Post
    Just as the MSD coils fail, the factory coils can fail. Many of the factory coils have well over 100K and have been through 10-15 years of bumps.
    Just another thing to consider.
  13. #13 Re: spark plug opinions
    Pennsylvania
    How much boost required to cause a misfire when gapped at 0.060?
  14. #14 Re: spark plug opinions
    SE Level Member Reverant GTP's Avatar
    Iowa
    Just curious since everyone else is going off track but generally doesn't everyone say 3.4 is too small with headers on 04+? What octane are you running and any kr?
  15. #15 Re: spark plug opinions
    Iowa
    Also agree if your not getting blow out no need to decrease. However gm across the board last time I knew decreased gaps from 60 to 45 due to better idle quality and no loss anywhere as far as performance... but maybe I'm wrong... I'm always open to opinions
  16. #16 Re: spark plug opinions
    Pennsylvania
    Quote Originally Posted by Reverant GTP View Post
    I've seen a 3.4 run without knock with plog+3"dp on 04+. I'm sure it was tuned pig-rich, but it ran. The tune can make up for some naughty modding. That kind of stuff is probably the vast majority of canned tune business.
  17. #17 Re: spark plug opinions
    Iowa
    Ahhh, makes sense
  1. which spark plug?
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2012, 07:39 PM
  2. The best spark plug for a 04 gt ???
    By PALMCASTER GT1 in forum General Tech Discussion
    Last Post: 11-16-2011, 10:05 PM
  3. Spark plug gap
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 01:55 AM
  4. Spark plug gap?
    By 91z in forum General Tech Discussion
    Last Post: 04-20-2011, 08:28 PM
  5. Spark plug
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-01-2011, 02:48 AM
