Thread: Electrical gremlins with headlights and blower motor, please help?
Results 1 to 7 of 7
  1. #1 Electrical gremlins with headlights and blower motor, please help?
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    2000 gp se with the base HVAC control module. I have the higher quality HIDs. My blower motor and headlights used to work perfectly. Ive replaced the blower motor resistor and the blower fuse is ok ( all fuses are ok). So whenever i move the blower switch from off, the headlights and blower will turn off. Sometimes If i move the switch to 5 and wait about 5 seconds my blower and headlights will turn on. The intermediate blower settings do not work at all ( thats why i thought it was the blower resistor). Any thoughts guys? I really appreciate any opinions.
  2. #2 Re: Electrical gremlins with headlights and blower motor, please help?
    probably the ignition harness gone bad.
  3. #3 Re: Electrical gremlins with headlights and blower motor, please help?
    Feb 2013
    Missoula, MT
    Ignition circuit off they key switch? If my car dropped ignition while i was driving, wouldn't the engine stop?
  4. #4 Re: Electrical gremlins with headlights and blower motor, please help?
    not sure what you mean there, but this is the how to. Sparky's Answers: 2002 Pontiac Grand Prix, Changing The Ignition Switch
  5. #5 Re: Electrical gremlins with headlights and blower motor, please help?
    Feb 2013
    Missoula, MT
    Ok thank you! I will be doing the test tomorrow to see if its my ignition harness.
  6. #6 Re: Electrical gremlins with headlights and blower motor, please help?
    they are not cheap really, so a junk yard or used maybe a good idea.
    theres a few part outs here in the parts for sale section. im sure dsmuts will pop in and say i have one of them lol or shoot him a pm.
  7. #7 Re: Electrical gremlins with headlights and blower motor, please help?
    Feb 2013
    Missoula, MT
    You were right, it was the harness. I decided to clean the terminals instead of buying a new one and it worked. It was easy getting to the switch pack thanks to the awesome people that take the time to post how-to threads. All the contacts on the metal levers inside the switch were either covered in a black build up or had melted pit spots. I took a razor blade, scraped off the build up and scuffed up the contact points so they looked like the new ones, and it works great! The hardest part is getting the spring inside the switch pack to line up right because it has to be tensioned when you put the cover on, but not too bad of a project. 0$, tools: PH2 screw driver, small flat screw driver, razor knife, needle nose pliers ( for the screws on the switch pack), torx bit for lower shroud, and a 5/32 socket. Hopefully this can help someone save some cash.
  1. POOR BLOWER MOTOR AIR FLOW (resistor and blower motor already replaced)
    By jsmit162 in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 10:22 PM
  2. Electrical gremlins
    By nos4blood70 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2012, 09:14 AM
  3. Need help with some electrical gremlins
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2012, 11:10 AM
  4. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  5. Fixed! blower motor, flashing headlights and dim information center
    By Mizzouri in forum General Tech Discussion
    Last Post: 10-02-2008, 02:37 PM
