Thread: Charging system issues. Help please
Results 1 to 4 of 4
  1. #1 Charging system issues. Help please
    Johnstown, NY
    So I've had a rather frustrating night trying to get my alternator working. Since 2 alternators arent working, both test good, and I know the 1 worked before I pulled the motor, I've turned to wiring.
    First I added a 0 guage wire from the alternator to the battery + terminal. I left the stock large red wire on the alternator connected. When I went to reconnect the + terminal to the battery, the starter engaged with the key removed. Same happens if connected to fuse box. Connected the fuse box to the battery + terminal. nothing happens.
    Next I removed the stock power plug from the alternator and ran the wire from the alternator to the battery. I was able to connect the terminals with no issues, and was able to start the car with the key.
    Now I know while a car is off and the windows are rolled up the headlights will dim and stay dim. With this setup the lights dimmed for about 0.5 seconds and quickly became bright again. This leads me to believe the alternator is working with that setup, though I dont have my multimeter handy to confirm this.
    So either the batt to alternator wires are broken or not connected somewhere, or the starter is wired wrong.
    The large red wire and the 2 small red wires (previous owner spliced to black wires of same guage using heat shrink and solder) that share the same connection are on the top prong. The purple wire which I know is correct is on the tiny terminal. The medium red wire (same story as the small red wires, appears orange in pic) is connected to the bottom terminal. Is this the correct wiring?
    Thanks in advance.
    98 Red Coupe Grand Prix GTP : 180* T-stat, U-Bend delete, NGK TR55's, SLP Catback
    My Ride: http://www.grandprixforums.net/jevik...upe-73301.html
    A must read for modding: http://www.grandprixforums.net/safel...0-a-67580.html
  2. #2 Re: Charging system issues. Help please
    you got all the grounds back on at the tranny bell housing? should be 3 there. the bat neg cable, plus 2 smaller wires.
    you'll need a volt meter to check how much the alt is putting out.
  3. #3 Re: Charging system issues. Help please
    Johnstown, NY
    I do have 3 wires connected to the tranny housing. I also cleaned up the neg terminal to chassis connection.
  4. #4 Re: Charging system issues. Help please
    Johnstown, NY
    I followed this diagram. And I see the 3 wires to the bellhousing.. Now look 1 bolt above that.. Is that the medium sized red wire? That might be the problem....
    http://ww2.justanswer.com/uploads/dr..._174902_30.gif
  1. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  2. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  3. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  4. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
