Thread: Lower T-Stat but same temps
Results 1 to 6 of 6
  1. #1 Lower T-Stat but same temps
    SE Level Member gtpterp's Avatar
    Jul 2011
    MD
    Hey guys,
    got another small question. If i put in a 180 T-stat shouldn't my fans come on at a earlier time. Right now it kicks in as if I still have a 195 in it. I shouldn't need a turn to account for the new T-stat right? Someone point me in the right direction .
    Thanks, GTPTerp
  2. #2 Re: Lower T-Stat but same temps
    antioch ill
    so im guessing you arent tuned for it then. you would have to get the fan turn on points adjusted for it to stay at 180
  3. #3 Re: Lower T-Stat but same temps
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Your fans aren't controlled by your t-stat, silly. They are still turning on at stock temps. You need to tune it so they come on at a lower temp.
  4. #4 Re: Lower T-Stat but same temps
    Jul 2011
    MD
    OK thanks guys for point me in the right direction! Still learning things!
  5. #5 Re: Lower T-Stat but same temps
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    The new tstat is opening at 180* and coolant is flowing. The problem is that unless your moving alot or at highway speeds your not getting enough airflow to maintain that temp. Thats why you have cooling fans. They keep air moving even when your car is not. Now your engine computer turns those on around 210 ish degrees stock. This is pretty dang hot if you ask most people here so that why everyone gets the pcm set up to turn the fans on around 185. This would be bad by itself because without a 180* thermostat your fans would just be pushing air non stop against a radiator that isnt flowing any coolant because the 195 degree thermostat isnt letting the engine get that cold. Thats why you need both.
    Recap:
    Just a thermostat = cooler temps if theres enough airflow but otherwise not much changed.
    Just a tune = fans running non stop
    Tune + Thermostat = Happy 180 degree engine
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  6. #6 Re: Lower T-Stat but same temps
    Jul 2011
    MD
    Thanks for making that clear! Really helps a lot
    '00 GTP: TOG headers with high-flow Cat, Borla exhaust, 3.4 Pulley drop, 180* Tstat, NGK TR55
  1. Suggestions for running lower temps?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2011, 03:28 PM
  2. crazy high trans temps or no temps!? pics!
    By blknbstd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2011, 06:07 AM
  3. FWI, T-stat and really cold temps
    By SomeDudeAtHome in forum General Tech Discussion
    Last Post: 08-14-2009, 06:41 PM
  4. Temps with 180* T-stat?
    By BiggRiggs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2009, 11:17 AM
  5. Hose temps- upper and lower (kinda dumb question I know)
    By diesan04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2008, 09:36 AM
