Thread: Help! new to site and grand prix's car runs like crap!
Results 1 to 20 of 29
  1. #1 Help! new to site and grand prix's car runs like crap!
    Apr 2013
    colorado
    I have a 97 grand prix gtp that I have had for a about 3 months now. Recently took a small trip about an hour and when I got back I had a CEL and car wouldn't run worth a crap. If I give it gas it won't rev over 1500 rpms and its popping and stuttering. I found a blown fuse that took care of my check engine light but I cannot figure out why it is stuttering so bad. It will idle fine but the second I give it gas it runs crappy. Replaced MAF because of CEL and replaced the fuel filter. I have 55 psi on the fuel pressure gauge. I tried the fuel pump tab on the relay and still same. Now I have no check engine light and car runs crappy. I do not have a tech scanner unfortunately just a can scanner that give me a small amount of live data. Any info or help would be great. Thanks!
  2. #2 Re: Help! new to site and grand prix's car runs like crap!
    What code did you have?
  3. #3 Re: Help! new to site and grand prix's car runs like crap!
    Apr 2013
    colorado
    P0102. Found a bad fuse under the hood and cleared this up. Also I fixed a wire by the coil pack plug that was digging into a bolt. This had brought up a crank sensor code but that is fixed now no codes. Still runs terribly, won't drive at all.
  4. #4 Re: Help! new to site and grand prix's car runs like crap!
    try unplugging the maf sensor.
  5. #5 Re: Help! new to site and grand prix's car runs like crap!
    Apr 2013
    colorado
    I have tried unplugging the MAF I even bought a diff one from ZZP. Same stuff. I tried unplugging the front o2 sensor as well.
  6. #6 Re: Help! new to site and grand prix's car runs like crap!
    Try pulling the front o2 out and see if it runs better you might have a clogged cat.
  7. #7 Re: Help! new to site and grand prix's car runs like crap!
    Apr 2013
    colorado
    Unplugged it already and it changed nothing. I have a full 3" exhaust front front to back. No Cat.
  8. #8 Re: Help! new to site and grand prix's car runs like crap!
    Quote Originally Posted by RuderGTP View Post
    was it bolted to the coil bracket stud? if so put it back, thats the ground for the icm.
  9. #9 Re: Help! new to site and grand prix's car runs like crap!
    Apr 2013
    colorado
    The wire was just a single wire rubbing against the bolt that hold the connector. I moved the wire and taped it up. This is crazy. I checked my intake tube I checked the data logs for all the sensors and they are all working fine. ECT is reading the coolant temp and changing as it idles. IAT is working. I may have to try and post a video of how it is running.
  10. #10 Re: Help! new to site and grand prix's car runs like crap!
    Apr 2013
    colorado
    The black wire that has a circle lug on it is bolted to the coil mount too still is wasn't that wire.
  11. #11 Re: Help! new to site and grand prix's car runs like crap!
    if playing with the crank and cam sensor harness made a code for a crank sensor come up, you may have a bad harness, or a bad crank sensor, they have been known to make a car run poorly, and stall while just driving.
    a bad icm can also do this, crazy as it sounds, more then one guy has had the icm tested and it passed, then they change it and the car runs better.
    keep in mind, the icm and crank sensor work together, if one is bad the other suffers, same goes for the harness, bad wires wont flow the right current, and it tosses a code.
  12. #12 Re: Help! new to site and grand prix's car runs like crap!
    Apr 2013
    colorado
    It only had that code when the wire was being shorted against the head of that bolt then it went away and hasn't come back.
  13. #13 Re: Help! new to site and grand prix's car runs like crap!
    Don't just unplug the o2 take it out of the exhaust
  14. #14 Re: Help! new to site and grand prix's car runs like crap!
    did you cut the wire, and strip it back and re solder it? or just moved it?
    broken insulation on wires will toss a code or make the car run bad. the crank sensor rarely sets the code when it goes bad too.
    what happens is the nice shinny copper wire turns brown, aka tarnishes, just like copper left outside, once its get air getting to it, this dry wire will travel up the wires, you need to strip the wires till you have clean shinny copper wire showing, then either solder in a new piece of wire, or just re solder, depends on how much wire is damaged inside the insulation.
    pick up some shrink tubes too. solder and shrink tubes is the best way to replace or repair wires. butt connector sucks. use them if you want to do it 2 times.
  15. #15 Re: Help! new to site and grand prix's car runs like crap!
    Apr 2013
    colorado
    Ok ill run out and check the inside of the wire. I could see some copper so I guess I figured it was a good connection. I would figure it would pull a SES light if a connection was broken.
  16. #16 Re: Help! new to site and grand prix's car runs like crap!
    Apr 2013
    colorado
    I did unplug my computer to check for dirty connections. Is there anything to do with relearn or something like that?
  17. #17 Re: Help! new to site and grand prix's car runs like crap!
    No it doesn't hurt anything
  18. #18 Re: Help! new to site and grand prix's car runs like crap!
    if the insulation is clearly open, get some soldering goods if you dont have them already, and then cut and check out the wire. if it dont have dry wire yet, it will later on for sure. if the wires is good and clean still at least you'll save your self from another headache later on.
  19. #19 Re: Help! new to site and grand prix's car runs like crap!
    Apr 2013
    colorado
    Ok I have cut, heat shrinked, and fixed this wire. No affect on the poor running. Grr lol. Hmm.
  20. #20 Re: Help! new to site and grand prix's car runs like crap!
    Pull the front o2 sensor out
  1. Hi my car runs like crap!
    By Nick03gpgt in forum Introductions/Noob Questions
    Last Post: 12-21-2012, 03:58 PM
  2. grand prix runs now... kind of a big deal
    By Poil336 in forum General Grand Prix Discussion
    Last Post: 05-20-2012, 06:44 PM
  3. 04 Grand Prix engine light on but car runs fine what could this be?
    By bjornbjorn in forum General Tech Discussion
    Last Post: 12-02-2011, 12:07 AM
  4. New lateral rod; Car runs crap
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2010, 02:26 PM
  5. Engine runs like crap!
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2009, 02:26 AM
