Thread: Getting ready for my gen v swap
Results 1 to 15 of 15
  1. #1 Getting ready for my gen v swap
    Howell, NJ
    In a week or so I'm gonna be doing my gen v swap. I have most of pieces the only thing I still need to pick up is 2 new sets of injector o-rings.
    The one thing I'm most concerned about is the alternator. I have a 97 gp, do I absolutely need a relocation kit, or the newer stlye bracket? I thought I remember reading somewhere that you could modify the alternator for it to fit.
    I've done a LOT of research so far, any other advice/tips?
    Thanks?
  2. #2 Re: Getting ready for my gen v swap
    Feb 2008
    I ended up going with the newer bracket/alt setup on my '97. I couldn't make enough clearance to work, and my old alt was on its wat out. I have an '04 alt/bracket and the relocation brackets, but if you go with the '99-'03 alternator, you won't have to worry about the relocation bracket. I do like the decoupling pulley on the newer alt, though.
    BTW, eBay is a great place to find an alternator and bracket extremely cheap. Most of the sellers offer a short warranty.
    Sent from my SkyRocket
  3. #3 Re: Getting ready for my gen v swap
    Howell, NJ
    Thanks I'll look on eBay.
    Also I'm on stock exhaust manifolds, for the time being. I'm gonna get headers drop a pulley and tune at the same time.
    For now I should be fine on the stock tune, correct?
  4. #4 Re: Getting ready for my gen v swap
    Feb 2008
    If you are keeping your stock TB, then you should be alright for now. I strongly recommend a wideband and some way to watch for knock before you consider dropping pulley sizes.
  5. #5 Re: Getting ready for my gen v swap
    Howell, NJ
    Yup stock tb, I'll probably port it before I get it tuned. And I also have an aeroforce to monitor knock.
    I could find the alternators on eBay but not actual bracket.
  6. #6 Re: Getting ready for my gen v swap
    Feb 2008
    They are labeled as belt tensioners or tensioner assemblies.
  7. #7 Re: Getting ready for my gen v swap
    Quote Originally Posted by DanGTP View Post
    This.
    Whatever pulley you were currently running...figure at least .2" sizes larger to keep the KR the same or less.
  8. #8 Re: Getting ready for my gen v swap
    Howell, NJ
    Well I'm on the stock pulley size.
    Why should I have to pulley up if theres the same amount of boost
  9. #9 Re: Getting ready for my gen v swap
    Feb 2008
    On a stock pulley, you'll be fine. When you plan to drop sizes, get a size or two larger than you would with a gen3. If you think you want to do a "standard 3.4 setup", go with a 3.5 for the genV. It is more efficient and makes a little more boost/flows more (cooler) air for a given pulley size.
  10. #10 Re: Getting ready for my gen v swap
    Howell, NJ
    Yez I know this.
  11. #11 Re: Getting ready for my gen v swap
    Feb 2008
    Sounds to me like you are good to go.
    Did you find the tensioner assembly/alternator bracket?
  12. #12 Re: Getting ready for my gen v swap
    Howell, NJ
    No I didn't bill got a gen v to fit in his 97 Bonne.
    Im gonna see if I can get enough clearance by taking off the plastic backing and shaving it down a bit.
  13. #13 Re: Getting ready for my gen v swap
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I cant say iv tried to fit one on a 97 before but it has been done without a tensioner setup swap. Personally I would just goto a self pull it yard and grab the newer style setup and make it easy for yourself.
    People thought I was lieing when I said I did my genV swap for 400$.... As long as you cut the lim bigger yourself, make your own evap blockoff, drill your tb for the pcv system, and get a genV off ebay for 280$ its a cheap and awesome upgrade. I made a whole 1psi more boost with 2 sizes larger pully. Less belt drag and more boost = a giant increase in smiles per mile.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  14. #14 Re: Getting ready for my gen v swap
    Howell, NJ
    "smiles per mile"... mi boosta.
    I bought my gen v and LIM for 320 shipped that included a metal supercharger gasket, l32 tb, all bolts and the evap.
    Metal LIM gaskets were 50 I think and the adapter plate i got for 60
    sooo like 430 total?
    I might be buying a new alternator and bracket from another member. I would go to a u-pull it but the're aren't really any around. Theres a junk yard down the road but im pretty sure they'll over charge me for it. How much would you think it would cost from a yard?
  15. #15 Re: Getting ready for my gen v swap
    Apr 2011
    South Dakota
    I pulled one for a buddie here and it was 15$ for the tensioner bracket and 20$ for the alt
    I love Decker<3
  1. About ready to cry..PLEASE help
    By TJs97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2013, 09:13 PM
  2. Get ready for my intake swap. Version 2
    By David GXP in forum 5.3L V8 (LS4)
    Last Post: 05-07-2011, 04:04 AM
  3. Ready to go!
    By Schoop in forum Introductions/Noob Questions
    Last Post: 01-25-2011, 08:33 PM
  4. So im getting ready to do a top swap, any advice?
    By thunder71173 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2011, 04:41 PM
  5. Getting ready to swap the tranny chain...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2008, 10:49 AM
