First off, if u want an accurate reading on the trans temp you must get the signal through the PCM or OBD2 port. I had an electric trans temp gauge and it was off by nearly 40*. I had my aeroforce gauge right below it, both reading trans temp and the one on the aeroforce is way more accurate. If i were you id get the aeroforce gauge. As far as the oil pressure sender, just remove that little grey and green plug, its literally anout 6 or so inches to the left of the oil filter. You have to remove the oil filter and passenger front tire to see it. There should be 2 wires comming out of a harness. Just simply unplug it and twist out the factory sender. Then use the brass fitting that autometer gives you, and plumbers white fitting wrap for the fittings, and tighten in the sender so it wont leak. Run the wire into the car, up to the gauge and your done installing the sender.
