Thread: Maintenance gone wrong - wires/plugs - NOT RUNNING
Results 1 to 20 of 36
  1. #1 Maintenance gone wrong - wires/plugs - NOT RUNNING
    SE Level Member HEVEYMETIL's Avatar
    Western New York
    I know this is a boring topic but I'm in need of help, desperately.
    2007 GT - 89000 miles. Wires came out - with a huge effort and cut hands - plugs came out quite easy and did not break while being removed.
    New wires - Autolite, stock. New plugs - Autolite 606 gapped at .060. Small amount of anti-seeze on the plug threads. Plugs went in fairly easy, except for the one I snapped, removed and replaced with another one (obviously). Did not torque to death by any means. New wires went on, with spark plug grease. I have checked the firing order over and over. All connections secure.
    When it starts, it start strong and about a second after, sounds like death. Roughest idle - surging - running rich - gets close to dying then sputters back to life...checked firing order again - everything fine - etc etc. Each cylinder is hot after running - but it's running rich.
    What am I missing - could I have cracked a plug putting them in? Bad wires??
    I have the old plugs - and am thinking about putting them back in and seeing if this fixes it. Is copper a problem? Everyone here says they're the best to run.
    Thank you for anything and everything.
    Warren
  2. #2 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Try removing that grease.
  3. #3 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    You taking about the di-electric stuff I put on the plugs/into the wires?
  4. #4 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Omaha, NE
    .60 gap? Seems pretty big to me...
    Edit: I can't read.
  5. #5 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Quote Originally Posted by HEVEYMETIL View Post
    Yes, too much can cause issues.
    Were the posts on the coils corroded at all?
    That's the factory spec. Reread it Brian.
  6. #6 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    Interesting. I noticed the boots were already greased, but I didn't think twice about adding more.
    And am I right in assuming that switching from Iridium (stockers) to copper should NOT cause these problems?
  7. #7 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    No, not in the slightest.
    I would look over the vacuum lines and other sensor connections such as the MAP as well. It's possible something was damaged while working and is now causing this issue.
  8. #8 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    gardner,mass
    you shouldnt of added grease and yes you could of cracked a plug and i gap at .055 for al 606s and yes copper is better because it exchanges heat better for supercharged cars to help fight detonation
    it helps to have a scanner to see whats misfiring also..
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  9. #9 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    I didn't respond to your other question: the coil posts looked fine to me, clean and un-corroded.
    My buddy said the same thing about the connections. I did rock the engine forward to access the back plugs. Everything seemed in placed. Is there a connection I should check that I may have missed, that may have come undone?
    I've stopped for the night because fatigue is setting in and I feel like I'm missing something easy. I appreciate all the advice in the meantime.
  10. #10 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    Quote Originally Posted by Ginseng View Post
    Perhaps I will drop the gap a bit to see if that works, AND use a qtip or toothpick to remove the excess goopy grease. I wonder if AdvanceA will let me use their scanner ...
  11. #11 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    gardner,mass
    also jusdt to make sure your firing order is 1,4,5,2,3,6 bottom to top on coils and 1,3,5 on front and 2,4,6 on back
    Also note plug on cylinder 6 cracks often do to putting socket on crooked from front o2 sensor
  12. #12 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    gardner,mass
    i worked at advance, they wont let you use there scanner but you could limp the car there. I have changed plugs and wires 200 times and last time i did my lim gasket i checked my firing order like 5 times thinking it was right cus i was fatigued and ended up realising i had 2 crossed after sitting for a minute and taking a break
  13. #13 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    I will never understand why they designed it that way..
    I bought a 1.5 3/8 extension tonight which worked way better for the fronts - what do you suggest for Plug 6??
  14. #14 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    gardner,mass
    be careful and use a spark plug socket
  15. #15 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Could the MAP sensor been jared?? With it above the #2 and arms down behind it pulling and jerking it could have gotten hit and the vacuum unplugged?? Just a thought..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  16. #16 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    gardner,mass
    Quote Originally Posted by dbextreme View Post
    what he said the vac lines are simple enough to trace
  17. #17 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    There is no way changing the gap 5 thou is going to make any change this significant.
    If this was happening at full throttle, then yes, tightening up the gap would help.
    But this is at idle. If the coils can't fire the plugs at this gap, either the coils, ICM, wires or plugs are bad.
  18. #18 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Nov 2009
    Tennessee
    Not only vacuum, check the electrical connections to. Another guy on here was doing something and tugged on the harness that drops behind the alternator and accidentally pulled a pin out of his 2 pin plug for the Speed Sensor.
  19. #19 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    Please tell me this is what we're referring to, and excuse my ignorance...
    <a href="http://s1354.photobucket.com/user/Warren_Teall/media/IMAG0802_zps0d7ae2b6.jpg.html" target="_blank"><img src="http://i1354.photobucket.com/albums/q692/Warren_Teall/IMAG0802_zps0d7ae2b6.jpg" border="0" alt=" photo IMAG0802_zps0d7ae2b6.jpg"/></a>
  20. #20 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Nov 2009
    Tennessee
    Yeah. Should have a nipple on it...
    Check this link for a pic of one:
    http://www.1aauto.com/1A/MAPSensor/P...FQ2znQodKl8ABw
  1. Plugs and wires
    By bjordan0223 in forum 5.3L V8 (LS4)
    Last Post: 08-17-2012, 07:53 PM
  2. Plugs?? Wires??
    By Speedy1973 in forum Engine
    Last Post: 06-22-2012, 09:14 PM
  3. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  4. Best plugs&wires for a 99 GTP
    By MurphysLaw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2010, 08:58 AM
  5. Plugs and Wires
    By Squishy in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-09-2009, 09:51 PM
