I have a 98 pontiac gtp supercharge. What do low range means???
Hi,
Moved this to a better section for you. The How To section is for write ups that help folks on how to do stuff.
Low Range on the DIC should coincide with the fuel gauge being low. Meaning the range of miles you have left in available fuel are low.
For a while now I have been hearing this beeping sound ( It dose it every now and then). I though it was because of my oil life and that I needed a oil change. I took my car to the shop (dealer ship) I had to replace my intake manifold gasket. So they had to change my oil. Now my oil says its at 100% I hit the mode bottom the next Thing I see is Low range. Now that I got my car out the shop When I'm driving you know how the green digital numbers that tells you how fast your driving that reflect off the winshell. Don't match what the speed says on the dase broad. Like the digital numbers that tells you how fast your driving can say I'm going 45mph, but the dash broad saying I'm only going 25 or 35. When I get up to 50mph on the dash broad it says I'm doing 100mph on the digital numbers that reflect off the winshell. It was take hella long to get pass 60mph on the dase broad even when I give it gas. Do you think the dealer ship f*** something up or didnt put something back on right????
Please note that next to the speed numbers it says kmh not mph. The fix for this is to press the metric/us button.![]()
i was just gonna ask that same question, because my regal will run low gas, turn the gas light on, then the info centers says low range, as in miles left you can travel.
if you have gas in the tank range will follow with a # that is the estimated miles you can travel still on said gas in the tank.
