Thread: What do low range mean???
Results 1 to 8 of 8
  1. #1 What do low range mean???
    Jun 2012
    Sacramento
    I have a 98 pontiac gtp supercharge. What do low range means???
  2. #2 Re: What do low range mean???
    Yoga city
    uhm in the dic?
  3. #3 Re: What do low range mean???
    Hi,
    Moved this to a better section for you. The How To section is for write ups that help folks on how to do stuff.
    Low Range on the DIC should coincide with the fuel gauge being low. Meaning the range of miles you have left in available fuel are low.
  4. #4 Re: What do low range mean???
    Jun 2012
    Sacramento
    For a while now I have been hearing this beeping sound ( It dose it every now and then). I though it was because of my oil life and that I needed a oil change. I took my car to the shop (dealer ship) I had to replace my intake manifold gasket. So they had to change my oil. Now my oil says its at 100% I hit the mode bottom the next Thing I see is Low range. Now that I got my car out the shop When I'm driving you know how the green digital numbers that tells you how fast your driving that reflect off the winshell. Don't match what the speed says on the dase broad. Like the digital numbers that tells you how fast your driving can say I'm going 45mph, but the dash broad saying I'm only going 25 or 35. When I get up to 50mph on the dash broad it says I'm doing 100mph on the digital numbers that reflect off the winshell. It was take hella long to get pass 60mph on the dase broad even when I give it gas. Do you think the dealer ship f*** something up or didnt put something back on right????
  5. #5 Re: What do low range mean???
    Jun 2012
    Sacramento
  6. #6 Re: What do low range mean???
    Please note that next to the speed numbers it says kmh not mph. The fix for this is to press the metric/us button.
  7. #7 Re: What do low range mean???
    PS, does your fuel gauge say you are empty?
  8. #8 Re: What do low range mean???
    i was just gonna ask that same question, because my regal will run low gas, turn the gas light on, then the info centers says low range, as in miles left you can travel.
    if you have gas in the tank range will follow with a # that is the estimated miles you can travel still on said gas in the tank.
  1. New sub box...where'd my range go?
    By Sven the Sexman in forum Audio, Security & Visual Electronics
    Last Post: 09-02-2012, 07:11 PM
  2. Trip to the range
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 02-27-2011, 05:10 PM
  3. mid range struggle
    By venge24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2011, 03:43 PM
  4. range rover
    By Davisgtp in forum Off Topic Discussion
    Last Post: 03-15-2010, 07:34 PM
  5. Bad MAP??? What should the range be?
    By l67fiero in forum PCM Tuning
    Last Post: 08-14-2009, 01:54 PM
