Thread: suspension knocking sound
Results 1 to 6 of 6
  1. #1 suspension knocking sound
    Apr 2012
    Windsor
    2005 grand prix gtp comp g
    160000kms
    Hey
    Im having a weird knocking sound on the driver side when i drive over any little bumps, its pretty loud too. It sounds as if the stabilizer link came lose on one end and was banging against the strut or control arm. I replaced my lower control arms with ball joints last summer, As well as stabilizer links and strut mounts. i used moog parts for everything so i do not think anything has failed, and the only other worn part i have the parts for but never got around to replacing is the inner and outer tie rods on both sides, could they be the possible cause? steering seems unaffected.
    i rocked the car in my driveway pretty good and was not able to recreate the noise, So i do not think its the strut,
    I am trying to avoid having to jack it up and pull the tire off, There is still a foot of snow in my driveway.
  2. #2 Re: suspension knocking sound
    jack the car up and do all the push pull tests for each front wheel.
    also check your sway bar mounts, the bushings under the caps breaks down, and the bar can clunk over bumps. or the sway bar end is broken, or the end links are shot.
  3. #3 Re: suspension knocking sound
    Apr 2012
    Windsor
    K i have it jacked up now with the tire off, there is no play in the wheel, sway bar/stabilizer link (same thing as far as i know) looks good, they only have about 8000kms on them, couldnt find play in anything, tried with a prybar, only thing i saw but i doubt is the cause, The lower control arm sits close to where the bottom bolt for the stabilizer link bolts in, they could touch but not over every little bump i hit, and its the same on the other side so i doubt thats the problem.
    IMG-20130330-00008_mini.jpg Photo by Linebacker_47 | Photobucket
  4. #4 Re: suspension knocking sound
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    How do your sub frame bushings look? Check out your trailing arms too.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  5. #5 Re: suspension knocking sound
    Apr 2012
    Windsor
    sub frame bushings are good, trailing arms i will be replacing this summer but they are not that bad. The noise is isolated to the front driver side tire, was able to test it going over speed bumps, I am leaning towards a possible strut issue.
    I know the comp-g came with stiffer suspension then the other GTP's, i was thinking of just buying zzperformance strut/spring combo with the gr2's. the struts i have now are completely stock, other than the mounts, so need to be replaced anyways, anyone know of a better pre assembled strut option? or is zzperformance gr2s good enough?
  6. #6 Re: suspension knocking sound
    Marysville WA
    I just dropped in the AGX strut spring combo from ZZP and I like it but couldnt give ya a side by side comparo, its beats stock!
  1. Knocking sound..
    By Jordin in forum Brakes/Suspension/Chassis
    Last Post: 02-29-2012, 09:52 PM
  2. knocking sound
    By casperyaj in forum General Tech Discussion
    Last Post: 03-27-2011, 08:43 PM
  3. knocking sound
    By scott1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 08:46 AM
  4. knocking sound from engine
    By BSP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 09:03 AM
  5. knocking sound
    By kenneth74gt in forum General Tech Discussion
    Last Post: 08-24-2010, 04:13 AM
