Any experience closing spark plug gap after light mods ?
Don't do it. Run the gap at .055ish
Yes, at some point there is a need to reduce the gap because it can be blown out.
You'd be at a pretty high power level to be needing to run anything under a .050 to .055 gap.
Roughly around the point where the supercharger turns into a turbocharger.
Or you're running a nasty blower setup/nitrous and need to close the gap some to prevent blowout.
Light mods no need to mess with gap at all.
What gap would you guys recommend for a build with XP Cam, Double Roller, Stage 2 ported heads, Gen v, 3.0 pulley, SD Headers, lQ4 MAF, FS I/C?
I usually do .054 so ill try. 055
Sent from my SGH-T989 using Tapatalk 2
close the gap if you start to misfire or lean it back out until it stops misfiring.
I run down to a 025 gap on the cheapo plugs to keep my turbo setup happy, so you can do it if you want.. it doesnt really hurt.
